Sounds fine to me. IIRC you don't want DC's over about 50% and the ICP at WOT should be about 2800 psi.
Want to feel better about it? At WOT in my truck I was at 2200psi and 90% DC
To really find out you need to run it kinda like on a dyno, from the bottom of say 3rd gear. This will tell you how it is doing. For example mine drops to about 1800 psi and in the 88%-92% DC. If you need help give me a call.
Do you want the easy, quick version or the drawn out one? The long explanation is click here
The quick version is get out and cruise at highway speed, then hold it at WOT from around 55 mph up to 90+. (using the data logging option so you can watch the road of course)
When you get back, watch the ICP to see where it peaked out at, then watch where it fell off to and see what pressure it could maintain.
On an acceleration run as Chris described in stock, it should stay as close to 2800psi as possible. A little less is okay, but below 2500 is getting weak.
