1993 E150 Emissions Failure
Old Mar 2, 2010 | 05:24 PM
jerrywagnersarah's Avatar
jerrywagnersarah
Need help diagnosing an emissions test failure for a 1993 E150.... failed Ontario's Drive Clean today, tests results below:
---------------40KPM Test------------Idle Test
-----------Limit----Reading----------Limit---Reading
HC ppm----71-------141----FAIL-----200------86----PASS
CO%------0.39------0.28---PASS----1.00-----0.09---PASS
NO ppm---1102------278----PASS----n/a-------n/a
Need help so that I can hopefully send the minimum amount possible to it. Have done the following within the last six months:
  1. Spark plugs/wires in Sept.
  2. New water pump/thermostat in Sept
  3. Oil change this morning before test
  4. PCV valve as well
  5. Lucas injector cleaner on last tank of gas ran till nearly empty
  6. Filled 1/2 way with 91 Octane w/up to 10% ethanol
Also, has an undiagnosed "miss" on initial light footed acceleration from a stop.... only when accelerator is slightly depressed.
Old Mar 4, 2010 | 06:46 AM
1993 E-150's Avatar
1993 E-150
does your exhuast smell real bad. mine smells rotting eggs black smoke
Old Mar 4, 2010 | 07:55 AM
jerrywagnersarah
No... it doesn't. Pulled the codes on it....
KOER --> 311
KOEO --> 327,332
Old Mar 4, 2010 | 08:47 AM
subford's Avatar
subford
KOER DTC 311 indicate that Secondary Air Injection (AIR) system is inoperative.
Possible causes:
-- Vacuum hoses leaking, blocked or kinked.
-- AIRB/AIRD valve, AIR pump inoperative.
-- AIRB/AIRD solenoid(s) damaged, blocked.
KOEO DTC 327 indicates that the EGR Valve Position (EVP) sensor signal is less than the Self-Test minimum value of 0.2 volt.
NOTE:
Because the EVP sensor is preloaded when attached to the EGR valve, a failure in the EGR valve causing the EVP sensor to lose preload may also set DTC 327.
Possible causes:
-- Damaged EVP sensor.
-- Damaged EGR valve.
-- Open harness.
-- Grounded harness.
-- Damaged Powertrain Control Module (PCM).
KOEO DTC 332 No shut code.
But Continuous Memory DTC 332 indicates that the EGR valve did not open with the engine stabilized and with EVR solenoid duty cycle present sometime during vehicle operation.
Possible cause:
-- Obstructed or cracked hose to EGR valve.
-- Damaged EVR solenoid harness.
Old Mar 4, 2010 | 10:35 AM
85e150's Avatar
85e150
Focus on the air pump.
Your CO is good, which means the cat is working.
Your NO is good, real good, which means your EGR is working.
HC is unburned fuel. So a miss will add to to it, or a lazy or partially blocked air injection, as per the prior post.
That's my WAG.
Good luck with it.
Old Mar 4, 2010 | 01:05 PM
jerrywagnersarah
Will focus on air injection system..... fairly certain that the air pump is functional... I was working on something else and had the inlet hose from the air pump disconnected from the air box and it had superb suction (almost insane) so I fairly certain that it is moving a good volume.... probably one of the solenoid/valves or the vacuum lines are problematic.
coach17
1983 - 2012 Ranger & B-Series
Sep 26, 2016 11:40 AM
adephue
15
Aug 15, 2014 06:06 PM
wr310rdr
19
Jun 3, 2013 02:27 AM
Sprintcar
Mar 23, 2011 03:45 PM
94f150failedsmog
Jan 20, 2011 07:09 PM
