Electric fan for PSD?
Anyone have experience or thoughts on the expected results?
Vehicle is a new-to-me 97 F-350 crew cab, long-bed, single rear wheel, 4x4, automatic PSD. My towing is a 19', 2000 lb boat, about 50 miles each way on good highways, very small & gentle hills on the Maryland western shore. Don't see myself going over about 24' / 3500 lbs for future boats, but might occasionally head up to an Appalachian lake.
Cutting the cabin warmup time is important because I'm to be paddling whitewater in the spring. Think standing in a muddy parking field in the middle of nowhere after several hours in low-40-degree water, air temperature is low 40s and dropping, and the breeze is picking up. Heat isn't just a comfort, it's a safety issue. More heat quicker = better. Oh, and using less fuel on a 400 mile or longer weekend excursion would be nice, too.
I know this is small potatoes to the folks who pull 5th-wheels halfway across the continent, but I'm looking to set this vehicle up nicely for my uses. Oh, 4" exhaust, aftermarket intake, gauges, and maybe a chip are probably also in the not-too-distant future.
Thanks for any help!
It will help with two cooling, not sure about warm-up.
Kind of expensive and the install looks a little complicated.
The Cyclone IS expensive, and I've got no idea what it takes to install a magnetic clutch. For less than 1/2 the price of a Cyclone, I can get 2, 16" electric fans & thermostats.
Hmm, the radiator might be big enough to take 2 of those mounted diagonally. One upper right behind the transmission cooler set a bit above thermostat opening temperature (help the tranny as much as possible), the other lower left set at a bit higher temperature. This sounds attractive, but I'll spend some effort to try & find out what cfm the Cyclone is rated at. Then, when it's warmer outside, I'll measure the radiator and start figuring out what will fit.
For the meantime, I can always block off some of the radiator with a piece of cardboard.
Thanks for the input, guys!
It's even smaller than that, 4.0 V6.
Airflow cross section for 2 x 19" electric fans x 2/3 derating factor (wild guess that the electric fans move 2/3 the air per cross-section unit) gives equivalent of a single 22" fan. Now how big is that stock fan?
Note from a prior post- I'm also the one with "no heat"; I suspected stuck thermostat and you (and several other people I talked to) concurred that sounded about right. Well, we were all wrong. New thermostat made at most a marginal improvement; I have confirmed that the heater core is HOT when the temperature gauge stabilizes. I'm used to fast-warming, stabilize-in-middle of gauge gas engines, and the PSD's behavior is apparently much different. I'm now pretty sure the problem is that the temperature blend door in the heater plenum is barely opening for heat. Now I just need a warm day to tinker with the linkage- and measure fan and radiator.
I'm also planning on installing an electric fan for quicker warmup, better highway efficiency, etc. What I'm looking at is the Flex-a-lite 290. It's a dual fan setup that flows 5500 cfm. It is just about the perfect physical size for the radiator, it's not a drop-in fit, but looks like an easy "custom" job... just some simple brackets and such. I've read about a couple people that have installed this fan on their PSD and they say that they get nice frosty A/C at idle, & their auto trannys and engines stay cool.
One thing I like is that it comes with an automatic variable speed controller, so it's not just and "on/off" fan.
Regarding the Cyclone, I've heard some good and bad things about the it, but the two things I don't like are
1) the viscous coupling is gone, so it's and "on-off" fan, and when it's on, it's LOUD. Plus it seems like a clutch that cycles on and off at engine speed is kind of hard on things...
2) apparently many people are having problems with the serpentine belt slipping with the stock fan, and the Cyclone would still have that problem since it uses the same pulley and belt. In fact I've read posts from Cyclone users that still have the "cycling fan" problem.
Anyway if you ever do install an electric it would be cool to hear how it worked out. When I get mine done (may be awhile) I'll post info too.
The 5500 cfm intrigues me- the dual 19" Hayden idea I concocted would be about 3900 cfm, if it even fits.
I'm loathe to compare gas to diesel cooling requirements without some good data. The 4.3 l gas S-10 I sold when I got the PSD had a MUCH smaller radiator- maybe 1/2 the frontal area or smaller, and it also wasn't as thick. My very rough thought is that the PSD has much more than twice the radiator VOLUME but less than twice the displacement of the gas engine. Seems like the PSD installation has notably MORE cooling per unit displacement than a gas engine- and even more on a per-horsepower basis. Maybe the PSD cooling system is over-engineered- or maybe the diesel DOES need the extra cooling under some circumstances. The latter possibility makes me want to be careful.
Examples to suport my reason are,
1; In my bus I can hear the fan kick in. Most of the time it doesn't even run. It still runs off the engine but has an electric clutch.
2; Another example why an electric fan may be ok to use is, We once had an idler pulling bust and to get it back to the shop we ran a shorter belt in there in such a way I can even describe. But to get the broken bolt out we removed the fan. Then we didn't even bother putting it back in for the 10 mile trip back to the shop. No overheating. That was in the summer with temps around 80 for a high.
I still wouldn't recomend an electric fan for use even if I thought I could get away with it.
