oil on intercooler pipe
Old Oct 15, 2010 | 06:12 AM
93FordCTD's Avatar
93FordCTD
I pulled the pipe and found a nice coat of oil in it, should I be concerned?
What can cause this? Truck (05 psd auto) has only 52k miles and I don't work it hard.
Also this engine (unmolested) seems to run hotter than My first gen cummins, lots of stuff on the front. I'm concerned all this heat could be too much for the tranny that has worked flawless for now but it is an auto, should I add a fan with a thermostat controlled switch?
Thank You.
Btw on a previous thread I asked about the engine not starting and I checked the plug You guys mentioned there was no oil in the electric part of the sensor, it didn't do it since then so I didn't have to fix anything but wth was that?
Old Oct 15, 2010 | 07:27 AM
l-m tech's Avatar
l-m tech
oil in the cac tubes is normal if its just a little and it isnt smoking.the turbo draws the oil out of the crank case vent.
Old Oct 15, 2010 | 10:55 AM
lawnboy1965's Avatar
lawnboy1965
Do the CCV re-route and it will clear up with time, mine is spotless.
Old Oct 15, 2010 | 08:42 PM
93FordCTD's Avatar
93FordCTD
As long as it is normal I don't mind but on My first gen if I see this I'm pulling the turbo for a rebuild job.
Thank You.
Old Oct 15, 2010 | 10:25 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
So you can have a good idea of where the oil comes from go to the pictures on this page. The crank case vents directly into your turbo. A lot of us have done a reroute of the vent through a filter.
https://www.ford-trucks.com/forums/7...e-route-3.html
Raymgriff
17
Mar 26, 2017 06:26 PM
2006powerstroke90
Nov 27, 2016 06:46 PM
jaymcjay
Sep 11, 2016 04:35 PM
KodiakF250
6.7L Power Stroke Diesel
Jun 15, 2016 03:10 PM
FiveOJester
Jan 17, 2016 03:41 PM
