4.9 ENGINE CHANGE
Old Mar 2, 2010 | 09:28 AM
malone55's Avatar
malone55
6th Gear
4.9 ENGINE CHANGE
Hi all, I have a 95 F150 auto trans 4x4 with a tired 4.9 litre.
I've bought a 94 F150 standard trans 2 wheel drive with low kms.
Planning to swap the engines around, the 94 has air in head and the 95 does not. Whats the best way around this? Change heads? Replumb?
Hmmm, Thanks for all responses in advance !!! <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Mar 2, 2010 | 11:14 AM
javi2001's Avatar
javi2001
Hi, can you clarify "...the 94 has air in head and the 95 does not..."
What means air in head?
Old Mar 2, 2010 | 12:11 PM
budford's Avatar
budford
He probably means air injection. The air injection that is plumbed into the head on certain years of trucks.
Old Mar 2, 2010 | 12:31 PM
rocketfootballer's Avatar
rocketfootballer
Just take out the pipe like fittings that fit in the head, and get bolts with the same thread. Then put some high temp silicon on them. It's not worth having them air pipes and such, so just bypass
Old Mar 2, 2010 | 02:40 PM
malone55's Avatar
malone55
6th Gear
Thanks for the info... hopefully it won't effect the emissions test if I remove the air tube !
Old Mar 2, 2010 | 07:07 PM
rocketfootballer
the emissions part i cant comment on, Good luck with that!! Isn't any sensors or anything, but i suppose it depends on the shop
Old Mar 3, 2010 | 06:46 AM
chrlsful's Avatar
chrlsful
javi2001 - Welcome (belatedly, for U got over 1,000 posts).
We (USA, Europe etc) went thru pollution controll U may not have...correct me if I'm wrong. It is/was piped from the exhaust up to reburn cleaner.
Have U seen the Argentine Fords there? How bout the 250 I6?
Old Mar 3, 2010 | 07:10 AM
javi2001's Avatar
javi2001
I do remember on local yards a couple of engines with some pipes on head. Ford Venezuela never assembly trucks here using 300 EFI, just carby versions. There are a few guys like me having 300 EFI because I did assembly my own truck after a mayor rollOver.
Emission is law here from 2000 and newer trucks/cars.
Old Mar 3, 2010 | 08:23 PM
chrlsful's Avatar
chrlsful
javi2001-
I'm on an 'aussie'/'down under' form and it is a nice experience, but is cross cultural & have made a few mistakes 8-0 (even tho it's english lang)!
Don't know how old U R or if vehicles 'stick around' / R seen in your circles but do U C the Argentine Fords? Some have MEAN 250s in them (stock/oem). I'd like to hear...
Old Mar 3, 2010 | 10:01 PM
javi2001's Avatar
javi2001
Nop... never
Old Mar 4, 2010 | 09:17 AM
chrlsful's Avatar
chrlsful
Nop... never
Thanks,
keep your eyes open, let me know of any fourms/sites down there that may follow them. There's models all over the world & it's a nice size.
I see modern engines grouping around that displacement. I see modern similar sixes as well.
sddesigns
New Jersey Chapter
May 7, 2010 12:14 AM
sddesigns
New Jersey Chapter
Apr 14, 2010 01:55 PM
sddesigns
New Jersey Chapter
Mar 15, 2010 02:29 PM
sddesigns
New Jersey Chapter
Feb 25, 2010 06:03 PM
