98 b 3000. p0301 code ?
Old Mar 2, 2010 | 10:39 AM
bgreen1922's Avatar
bgreen1922
on this truck the #5 cylinder is pluggedinto the front driver side spot on the CP. that is how it was before I touched anything. I get 12.1 when testing between these two sockets. I gel O.L. whon testing from #1 to any of the other sockets on the CP.
Old Mar 2, 2010 | 10:54 AM
powersmoked's Avatar
powersmoked
My bad #5 is drivers side front. You should have 13-15k ohms. Test the the conector on the side of the coilpack. There are 3 small tabs. Change your mm setting Probe the middle and a side terminal you want less than 5 ohms not 5,000 ohms
Old Mar 2, 2010 | 10:56 AM
bgreen1922's Avatar
bgreen1922
Also I get continunity - no resistance between each pin where the flat connector plugs into the CP
Old Mar 2, 2010 | 10:59 AM
powersmoked
Test the other pairs on the CP. These are the pairs 1/5 2/6 3/4. You want between 13-15k ohms the #4 cylinder is drivers side front
Old Mar 2, 2010 | 11:03 AM
bgreen1922's Avatar
bgreen1922
Are you talking about measuring between the socket on the CP and and where that flat connector plugs into the side of the CP? That is where I get 25.7 ohm from #5 socket and eache of the pins in the flat connector. There are 4 pins in that flat connector.
I get 13.5 ohm from #1 socket to each of those pins in the flat connector.
I get O.L. from all other sockets to the pins in the flat connector.
Old Mar 2, 2010 | 11:05 AM
powersmoked
If you have an open circuit on the side terminal the CP is prob bad bring it to an autozone they can test it. Let us know what happens. Buy a manual while you are ther
Old Mar 2, 2010 | 11:07 AM
bgreen1922's Avatar
bgreen1922
on the CP
socket 1-5 =12.1 ohm
socket 2-6 = 12.1 ohm
socket 3-4 = 12.4 ohm
All on the 40k ohm on the mm
Old Mar 2, 2010 | 11:09 AM
bgreen1922's Avatar
bgreen1922
Ok. Sounds like its bad to me as well. Thank you so much for all your help!!
I will let you guys know.
Old Mar 2, 2010 | 11:10 AM
powersmoked
The sockets get testing together and the pins on the side terminal get tested together. You DO NOT test from a socket on the top of the CP to the to the pins on the side
Old Mar 2, 2010 | 11:14 AM
bgreen1922's Avatar
bgreen1922
Ok. Got it.
Between each of the pins on the flat connector I get contunity. 0 resistance.
powersmoked
You can also search and see if you have a seperate ignition control module or if it is part of the PCM
Old Mar 2, 2010 | 11:18 AM
bgreen1922's Avatar
bgreen1922
If that is the case maybe the CP is ok. As long its ok to have contunity between each of tthe pins.
Old Mar 2, 2010 | 11:23 AM
  #28
powersmoked
The CP might be OK the 12kohms is a little low. you can get it tested for free while you are doing that figure out if you have an seperate ignition module they will test that for free also. It is prob one of those two
Old Mar 2, 2010 | 12:39 PM
  #29
bgreen1922's Avatar
bgreen1922
Ok. had the cp tested at autozone and they said it was fine. I was testing the pins wrong before. He also said that the ignition mod was built into the cp. Not sure if he knows what hes talking about. Now dont know what to do.
Old Mar 2, 2010 | 12:54 PM
  #30
powersmoked
I think he meant the ignition module was built into the PCM. Go join therangerstation.com and post in the 3.0 engine forum
