Resetting the Key less Entry Key Code
Old Mar 2, 2010 | 05:15 PM
OutlawNomad's Avatar
OutlawNomad
Originally Posted by dzldenny
It's up to you, but I am too tight to pay for something I can do for free. I had to go about 1/3 of the way through that number before I found the code. It was cold out that day and my finger got sore before the pad did. I don't think you have to worry about the pad though. If you read some of those other threads, there are tons of people who have used this method to find the code. I don't remember one of them saying they had trouble with the pad. But like I said it's up to you. Good luck.
Did the keypad start blinking with you?
Old Mar 2, 2010 | 05:18 PM
OutlawNomad
To make it easier it broke it up into 5 easy groups, its easier on the eyes
99991 11113 11115 11117 11119 11133 11135 11137
11139 11153 11155 11157 11159 11173 11175 11177
11179 11193 11195 11197 11199 11313 11315 11317
11319 11333 11335 11337 11339 11353 11355 11357
11359 11373 11375 11377 11379 11393 11395 11397
11399 11513 11515 11517 11519 11533 11535 11537
11539 11553 11555 11557 11559 11573 11575 11577
11579 11593 11595 11597 11599 11713 11715 11717
11719 11733 11735 11737 11739 11753 11755 11757
11759 11773 11775 11777 11779 11793 11795 11797
11799 11913 11915 11917 11919 11933 11935 11937
11939 11953 11955 11957 11959 11973 11975 11977
11979 11993 11995 11997 11999 13133 13135 13137
13139 13153 13155 13157 13159 13173 13175 13177
13179 13193 13195 13197 13199 13315 13317 13319
13333 13335 13337 13339 13353 13355 13357 13359
13373 13375 13377 13379 13393 13395 13397 13399
13515 13517 13519 13533 13535 13537 13539 13553
13555 13557 13559 13573 13575 13577 13579 13593
13595 13597 13599 13715 13717 13719 13733 13735
13737 13739 13753 13755 13757 13759 13773 13775
13777 13779 13793 13795 13797 13799 13915 13917
13919 13933 13935 13937 13939 13953 13955 13957
13959 13973 13975 13977 13979 13993 13995 13997
13999 15153 15155 15157 15159 15173 15175 15177
15179 15193 15195 15197 15199 15317 15319 15333
15335 15337 15339 15353 15355 15357 15359 15373
15375 15377 15379 15393 15395 15397 15399 15517
15519 15533 15535 15537 15539 15553 15555 15557
15559 15573 15575 15577 15579 15593 15595 15597
15599 15717 15719 15733 15735 15737 15739 15753
15755 15757 15759 15773 15775 15777 15779 15793
15795 15797 15799 15917 15919 15933 15935 15937
15939 15953 15955 15957 15959 15973 15975 15977
15979 15993 15995 15997 15999 17173 17175 17177
17179 17193 17195 17197 17199 17319 17333 17335
17337 17339 17353 17355 17357 17359 17373 17375
17377 17379 17393 17395 17397 17399 17519 17533
17535 17537 17539 17553 17555 17557 17559 17573
17575 17577 17579 17593 17595 17597 17599 17719
17733 17735 17737 17739 17753 17755 17757 17759
17773 17775 17777 17779 17793 17795 17797 17799
17919 17933 17935 17937 17939 17953 17955 17957
17959 17973 17975 17977 17979 17993 17995 17997
17999 19193 19195 19197 19199 19333 19335 19337
19339 19353 19355 19357 19359 19373 19375 19377
19379 19393 19395 19397 19399 19533 19535 19537
19539 19553 19555 19557 19559 19573 19575 19577
19579 19593 19595 19597 19599 19733 19735 19737
19739 19753 19755 19757 19759 19773 19775 19777
19779 19793 19795 19797 19799 19933 19935 19937
19939 19953 19955 19957 19959 19973 19975 19977
19979 19993 19995 19997 19999 33333 53333 73333
93335 53335 73335 93337 53337 73337 93339 53339
73339 93353 53353 73353 93355 53355 73355 93357
53357 73357 93359 53359 73359 93373 53373 73373
93375 53375 73375 93377 53377 73377 93379 53379
73379 93393 53393 73393 93395 53395 73395 93397
53397 73397 93399 53399 73399 93535 53535 73535
93537 53537 73537 93539 53539 73539 93553 73553
93555 53555 73555 93557 53557 73557 93559 53559
73559 93573 73573 93575 53575 73575 93577 53577
73577 93579 53579 73579 93593 73593 93595 53595
73595 93597 53597 73597 93599 53599 73599 93737
53737 73737 93739 53739 73739 93753 93755 53755
73755 93757 53757 73757 93759 53759 73759 93773
93775 53775 73775 93777 53777 73777 93779 53779
73779 93793 93795 53795 73795 93797 53797 73797
93799 53799 73799 93939 53939 73939 93955 53955
73955 93957 53957 73957 93959 53959 73959 93975
53975 73975 93977 53977 73977 93979 53979 73979
93995 53995 73995 93997 53997 73997 93999 53999
73999 95555 57555 59555 77555 79555 97555 99557
57557 59557 77557 79557 97557 99559 57559 59559
77559 79559 97559 99575 77575 79575 97575 99577
59577 77577 79577 97577 99579 59579 77579 79579
97579 99595 97595 99597 77597 79597 97597 99599
77599 79599 97599 99777 77977 79977 97977 99979
79979 9999
Old Mar 2, 2010 | 10:10 PM
dzldenny's Avatar
dzldenny
No mine did not blink. I wonder though..are you entering the numbers as those 5 digit codes or as one code? Just trying to figure out why you are having issues thats all. If you pause too long between numbers, it wont work. It is meant to be entered as one number until the lock pops. For instance. If you enter the first seven digits in one after the other with no pause, you will have entered three possible codes. 99991 and 99911 and 99111 ect. Every time you press a button, it can only remember the last five you did. The sixth from the last gets dropped automatic. As an example, If your code is 12345 you can enter 6578412345 and the locks will open.
Do you have an owners manual with the truck? It will show you how to program your own number once you find the factory code. Some folks have entered the 1300 digit sequence, found a code only to find it was an erasable one from a previous owner. If that happens continue entering the sequence until it pops again. That should be the factory code. You don't have to start from the beginning again. Just though I'd give you the heads up before it happened. I was lucky and the first set I found was the factory code.
I sure hope you get it.
Old Mar 2, 2010 | 10:37 PM
beachcomer1962's Avatar
beachcomer1962
try this it worked for my ex
<table border="0" cellpadding="0" cellspacing="6" width="100%"><tbody><tr><td nowrap="nowrap"> xTraveler <!-- BEGIN TEMPLATE: postbit_onlinestatus --> <!-- END TEMPLATE: postbit_onlinestatus --> ******** type="text/javascript"> vbmenu_register("postmenu_3891582", true); *********>
</td> <td width="100%"> </td> <td nowrap="nowrap" valign="top"> Join Date: Jul 2006
<!-- BEGIN TEMPLATE: postbit_reputation --> <!-- END TEMPLATE: postbit_reputation -->
</td> </tr> </tbody></table> <!-- / user info --> <!-- message, attachments, sig --> <!-- message --> OK, for some reason they don't come up on a FTE article search but while searching google I found these instructions which actually come from an FTE article. They are by far the most detailed set of directions I've seen.
Security Keyless Keypad Programming on 2002+ Super Duty and Excursions
(Note: These instructions should work with other Ford's as well. If you have specific locations and supplemental information for other Ford trucks and suv's please let us know).
When your vehicle was newly purchased from the dealer it came with a card in the owner’s manual packet that had the keypad code on it. The packet is often lost over time and as the vehicle trades owners the code to the Keyless Entry is lost. Ford Dealers wants some big money to get the code for you by plugging in their computer to retrieve the code or using the following method. There is a much easier way for you to get the code and you don’t need any tools or automotive knowledge. I’ll show you how and where to find the code and how to reset the Keyless Entry back to the factory code or your personal code number.
There are three ways to find to it. One is a lot easier than the other but less work if you have a good eye and great flashlight. There are some Excursions, F250 and F350s that have a different wiring system so the first location to look is just above the right front kick panel; the RAP module is black in color with the numbers on the front the same as the white module. If you look above the kick panel you can see it really clear without taking anything apart. If it is not at this location please follow the next step.
This part is not hard to do you will need to remove the front cover under the steering wheel that says fuse box. (It has 4 plastic screws to remove) under the dash, the five (5) digit code is on the Cream/white box behind the radio, look to the top right of the open fuse box cover through the wires. (Towards the fire wall look through where my finger is pointing). At the back firewall, look for a 5 digit code on a sticker on a cream/white box. This is not easy but if you try every angle I promise it will appear don’t forget to use a very powerful flashlight if you want to see it.
The second way is a more time consuming job because you have to remover the stereo and to the rear you’ll be able to see the 5 digit code very easy. This process can take 2-10 minutes.
This is a picture of the Remote Anti-theft Personality (RAP) module. This is the module you are looking for there is nothing that identifies it as the RAP module (Some RAP modules are Black in color & it could also be up side down). It is the only box in the dash with the large bold type set with five numbers on it these is the five (5) digit code you will need from the module. Write this number down this is the factory code for your Keyless Entry.
Now that you’ve got the code I’ll tell you how to use the Keyless entry and set-up your own code.
Make sure when pressing the controls on the keyless entry keypad you press the middle of the buttons to ensure good contact with the controls.
Programming Your Own Personal Entry Code
1. Enter the factory-set code (keypad will illuminate when first digit is pressed).
2. Press the 1/2 control within five seconds of step 1.
3. Enter your personal 5-digit code. Enter each digit within five seconds of the previous one.
Your personal code does not replace the factory-set code. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code. The factory-set code can not be erased.
Erasing Your Personal Code or A Prior Owner's Code
1. Enter the factory-set code.
2. Press the 1/2 control within five seconds of step one 1.
3. Press the 7/8 and 9/0 controls at the same time within five seconds of step two.
The system will now only respond to the factory-set code.
Unlocking the Doors
1. Enter either the factory-set code or the personal code (Each digit must be pressed within five seconds of the prior digit). The interior lights will illuminate as soon as the first valid digit is pressed.
2. To unlock all the doors, enter the factory set code or a personal code and press the 3/4 control within five seconds of the drivers door unlocking.
Locking the Doors
1. Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered to lock the doors.
Deactivating/Activating Auto-lock
1. Enter the five 5-digit code.
2. Press and hold 7/8 control.
3. Press and release 3/4 control while holding 7/8 control.
4. Release 7/8 control.
The horn will chirp once if auto-lock was deactivated or twice if auto-lock was activated
Old Mar 4, 2010 | 02:34 PM
OutlawNomad
Great Article
Old Mar 4, 2010 | 02:40 PM
OutlawNomad
Found this on the inside of my fuse panel, it didn't work, the codes continue..
Old Mar 4, 2010 | 02:43 PM
OutlawNomad
Ok, Just some clarification here.
When hitting these buttons
(1-2) (3-4) (5-6) (7-8) (9-0) for instance in my code is 1,2,3,4,5 do I hit the half of the button that has the 1? or do I depress the entire (1-2) key?
Old Mar 4, 2010 | 02:48 PM
tdappleman's Avatar
tdappleman
Outlaw - I've got an 03 EB as well and the pictorial instructions above were not the same as mine. Look inside the dash almost directly behind the climate controls. You'll see a section of white insulation closest to the climate control module. Move that out of the way and with a mirror look at the black box the insulation was covering up - it will have a label on it and that will be your code. Good luck reading it backwards with the mirror....
Old Mar 4, 2010 | 02:57 PM
OutlawNomad
That sounds like something straight out of the ford owners manual,
get in the truck, tie your shoe lace, blink with your left eye, turn the ignition to on BUT DON"T START THE ENGINE, buckle your sealt belt, wave hello to a stranger.
Ill give it a try, thanks
All this to save 50 bucks and I drive a vehicle that gets 10 MPG hahhaha
Old Mar 4, 2010 | 08:18 PM
dzldenny's Avatar
dzldenny
You can just press the whole button for 1 or 2 ect. No need to press left or right side.
Your owners manual take sounds about right. Did you forget to put your left knee cap in your right ear? Luvit!
Old Mar 4, 2010 | 09:47 PM
OutlawNomad
Ok this was helpful,
I was entering the first 5, then stopping _ _ _ _ _ then entering the next 5 _ _ _ _ _ then stopping so on & so forth.
You are saying I should enter the numbers 6578453938012412345 (3 seconds apart ) and once it hits the 12345 it will open .. Ahh I get it.
Old Mar 4, 2010 | 10:08 PM
EXv10's Avatar
EXv10
The '00 and 01' models don't have the # under the dash.
Old Mar 5, 2010 | 06:26 PM
  #28
inkertinker's Avatar
inkertinker
I found my code today using info from post #19
Old Mar 5, 2010 | 06:53 PM
  #29
dzldenny's Avatar
dzldenny
Not necessarily should but could. I believe they have to be entered less than 5 seconds apart to work. When I did mine I would enter three digits with my right hand and cover them on my printout with my finger on my left hand and I could look back and get the next three ect. If I tried to do more than three at a crack I would forget. If you have someone who can read off the numbers for you it would be much easier. Once I had found my code I circled it on the printout and put it in the owners manual on the page with the directions how to program the personal number.
Old Mar 5, 2010 | 08:04 PM
  #30
beachcomer1962
your welcome... I found it very informative myself
beach
