brake booster interchange
Old Mar 1, 2010 | 12:01 PM
yak's Avatar
yak
i have a 1983 f150 with a leaky brake booster...i have many 89 and up f150s for parts... will the booster interchange?
Old Mar 1, 2010 | 05:53 PM
Eddiec1564's Avatar
Eddiec1564
It will not probly interchage with the mastercylinder. Ford did make boosters/MC a matched pair for your vehicle weight. On my 84 F250 the PO replaced the booster and mastercylinder from another truck. Well when I had to replace the MC I could not get the mounting correct. After going back and forth I had to "modify" the correct Master cylinder to fit the booster(had to widen the mounting holes) for my vehicle weight class.
Now if you replace both at same time and going with the newer master cylinder as long as its for your weight class, it probly work.
Old Mar 1, 2010 | 08:24 PM
bghnkinf250's Avatar
bghnkinf250
According to Rock Auto, 1984 to 1988 interchange. I do not know if there would be much difference between 1983 and 1984, theoretically, they could work.
rvpuller
6.2L V8
Nov 13, 2016 05:23 AM
Rusty_S
Oct 1, 2016 11:34 AM
brian1080
Jul 28, 2016 10:30 AM
Stewart_H
May 13, 2010 03:55 PM
Dylansdad
Mar 26, 2007 08:43 PM
