bypass fuel tank selector valve?
Here is another one on taking the switch apart.
https://www.oilburners.net/threads/fsv-tear-down.50770/
Charlie
Charlie
I bypassed my fuel tank selector valve a long time ago due to it not working i had no symptoms other than it not switching tanks. After I bypassed the valve I unplugged it and took it out and my gauge didnt work I plugged it back in and my gauge worked again so maby a bad valve can cause your gauge to stop working.
A bad selector valve will many times report a fuel tank overfull on the gauge. If it is stuck in the middle it can cause fuel to be drawn out of one tank and return to the other tanks also. Another problem crops up when they get stuck also - it will supply some fuel but not enough to properly operate or start the engine and people will spend tons of time and $$$ trying to chase down problems when in reality it is the stuck valve causing the havok.
Just wondering, why would you have to cut the wires to the selector valve connector?
Thanks for the info, I have a 1988 F Superduty/450 cab and chassis, dual tanks, 460ci gas, 2wd.
I plan on deleting the rear tank because I can't find a replacement for the rear plastic one and the sending unit wire are broken off in the wiring harness connector plus I found a 100 gal aux. tank on marketplace for a reasonable cost and will be installing that instead.
-Joe
-Joe
lud04X
12-03-2011 09:58 PM
AaronOregon
09-16-2009 01:03 PM
CruiserSHO
11-22-2006 09:03 AM
DHendricks
03-01-2002 10:51 PM
