bypass fuel tank selector valve?
Old 03-01-2010, 10:49 AM
Dislexiq's Avatar
Dislexiq
Dislexiq is offline
Is is possible to bypass or remove the ftsv? I will only be using my front tank, and not my rear tank at all. Someday way off in the future I may add a larger second tank in the rear, but until then, I really have no use for it. Suggestions?
Old 03-01-2010, 11:16 AM
Hamberger's Avatar
Hamberger
Hamberger is offline
Fuel Tank Selector Valve
No problem.
Just connect the feed and return to/from the engine to the feed and return to/from the Front tank. Two short fuel hoses and a few hose clamps should do the trick, only problem is you will have to cut all the connectors so putting the selector valve back later would be a pain to do. Maybe cut the lines a few inches away from the switch so you can splice them back together later.
There is very little pressure/vacuum on the return/feed lines (fuel pump is located at the engine). Keep your switch set to the front tank so your dash fuel gauge keeps working with the signal from the front tank.
Is your selector switch leaking? If not why not just leave everything and keep it set to the front tank?
Good luck,
Sebastian.
Old 03-01-2010, 01:10 PM
Dislexiq's Avatar
Dislexiq
Dislexiq is offline
ok, sounds easy enough. No, it's not leaking, I just have never had it switched to the rear tank and was trying to prevent any possible issues by doing so. Once I get everything situated, I will be the only one driving my truck, so just leaving things as they are and leaving the ftsv set to the front tank may be the smartest way to go. Thanks for the input
Old 03-01-2010, 01:15 PM
Hamberger's Avatar
Hamberger
Don't switch it
I will be the only one driving my truck, so just leaving things as they are and leaving the ftsv set to the front tank may be the smartest way to go. Thanks for the input[/quote]
If you have not used the rear tank in a long time you could open up a mess of trouble if you did use the switch. It may get stuck when you try to switch it and then you got a real problem not being able to get it back.
Leaving things alone might be the best thing here.
I always switch my tanks frequently to prevent the switch from fouling/sticking. Done that on both my trucks for almost 20 years, never had a problem.
Seb...
Old 12-11-2014, 02:29 PM
86gary's Avatar
86gary
86gary is offline
What does the fuel selector valve act like when it goes out? Does it allow air from the return to enter the intake? Does it make my fuel gauge not work correctly?
Old 12-11-2014, 02:43 PM
Hamberger's Avatar
Hamberger
Fuel Selector Valve failure
I never had one fail so don't know what the symtoms might be.
My rear tank gauge has been acting up recently on my 91 F350. The needle starts to swing widly and show F as the tank goes below an 1/4 of a Tank. Eventually it goes to E The sending unit must be shorting out once it reaches the bottom of the tank. Front tank is ok so it has to be the sender unit in the tank. Oh well, a project for another day, I hate pulling tanks...
Seb....
Old 12-11-2014, 05:49 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
some fuel tank selector issues could cause symptoms like;
not switching tanks.
switching tanks but fuel gauge reading incorrect tank.
air intrusion/rough running.
no fuel gauge readings.
semi working - but fuel returns to opposite tank that you have selected.
Old 12-11-2014, 06:40 PM
86gary's Avatar
86gary
86gary is offline
that sounds like it. I will swap it out with my parts truck and let y'all know if it works
Old 02-13-2019, 12:58 PM
Jason Cate's Avatar
Jason Cate
Jason Cate is offline
Need help
I recently bought a 93 f350 7.3 idi. Selector switch wasn’t hooked up in cab. I hooked it up and flip the switch. Now the truck is stuck on rear tank only. Found out there was a hole in the tank so rear tank is shot however I can’t get truck to switch back to front tank and run. I want to bypass the selector valve but got to get the truck back to front tank. Suggestions?
Originally Posted by Hamberger
No problem.
Good luck,
Sebastian.
Old 02-13-2019, 02:43 PM
Olds64's Avatar
Olds64
Olds64 is offline
You can always get rid of the electric tank selector valve. Check out this thread!
https://www.oilburners.net/threads/m...l-pumps.71152/
You can also buy a parts store replacement for the tank selector valve.
Amazon Amazon
Old 10-23-2020, 06:03 AM
imdignit1's Avatar
imdignit1
imdignit1 is offline
CHECK THE SENDING UNIT PICKUP
Old 06-30-2021, 11:25 AM
JWhenman's Avatar
JWhenman
JWhenman is offline
4wd Low
Switch sticking
Seb...[/QUOTE]
Hi,
Is there a way to unstick the valve?
Old 06-30-2021, 02:58 PM
Perk85F250's Avatar
Perk85F250
Perk85F250 is offline
Never tried to unstick one. I suppose you could try tapping on it while another person flips the switch back and forth from front and rear tanks. Worth trying, but it would be difficult to know if it switched properly. The gauge may switch to the other tank without moving the valve to the other tank. Gauge may read one tank while fuel is pulled from the other.
Old 07-02-2021, 12:35 AM
Edward Michael's Avatar
Edward Michael
Edward Michael is offline
I love that we have to send guys to other forums!_)))000))))
With my tanks out therefore disconnected, the tank selector switch did not switch the tanks from front to rear while running (off a can).
dunno what that means
Old 07-09-2021, 11:04 AM
Charmalu's Avatar
Charmalu
Charmalu is offline
Quick Reply: bypass fuel tank selector valve?
