Sponsored by: Real Truck
2000 F-350
Old Feb 28, 2010 | 11:03 PM
superstroker123's Avatar
superstroker123
2000 F-350
Does anyone know if the factory trailer plug on a 2008 plug in to a 2000 harness
Old Mar 2, 2010 | 02:32 PM
A H DEVELOPMENT's Avatar
A H DEVELOPMENT
I would think it would, I think all trailer plugs follow the same standard guidelines & design.
Do you know if a 2008 plug is the same as a 2000 plug?????? If so you should be good to go, superstroker123.
Old Mar 2, 2010 | 11:02 PM
superstroker123
i know that they both have the flat four and flat seven plugs
Old Mar 3, 2010 | 01:13 PM
A H DEVELOPMENT
I am not really sure but I would think they would have the same wiring at least, because they operate the same things, so I think the 2000 & 2008 plugs & harnesses are interchangeable,I think. The only thing though, is the wiring color code probably changed during those years, which could make wiring a little more time consuming and confusing. There are tow vehicle/trailer wiring diagrams and color code charts out there on the web, I think Hopkins has one, you might find a definite answer there, superstroker123.
Old Mar 3, 2010 | 11:33 PM
superstroker123
im just wanting to unhook mine off the 2000 at the quick connect connector mounted to the frame and plug the 08 one in if the plugs are the same then i shouldnt need to do any wiring right
Old Mar 5, 2010 | 03:20 PM
A H DEVELOPMENT
Probably not if the plugs are the same, however its possible Ford redesigned the wiring/connector layout on the 2008 quick connect plug, so some things might be switched around. But I would just go ahead try it if the plugs fit and then hook up a trailer that has a seven plug connector on it and test it. (best if you use one with trailer brakes) Good Luck, superstroker123
Dogmann
Jul 18, 2014 11:34 PM
velocity tom
Nov 13, 2011 09:16 PM
oldred2000
1983 - 2012 Ranger & B-Series
48
Oct 20, 2010 02:43 PM
93F250
Modular V10 (6.8l)
Mar 24, 2008 08:18 PM
