Sponsored by: Real Truck
6.0 no start
Old Feb 28, 2010 | 06:41 PM
ArcticRider's Avatar
ArcticRider
6.0 no start
hello, i have a 03 250 with a 6.0 just got back from a 1500 mile trip problem free, the next eavning would not sart, thought i had got bad fuel so i added some more anti gel and plugged it in. in about an hour it went ahead and started but did nont like it, every thing was fine so i figured that it was bad fuel since then i have filled up and then a few days later it did it again i started to think it was the HPOP but now i have dtc's for all 8 injectors do you think that the FICM could be causing this and also its seems like as long as the truck is warn or i plug it in it will start fine but its 40deg out and the only time that i have had to plug this truck in was when its 20-30 below, if any one has any ideas please help. thanks, joe
Old Feb 28, 2010 | 06:51 PM
Surge08's Avatar
Surge08
almost sound like an high pressure pump, was an major issue on the early 6.0L
Old Feb 28, 2010 | 07:36 PM
06silvercrew's Avatar
06silvercrew
Go to the 6.0 forum and check out the stickys and troubleshooting tips, lots of great info there, aswell as some VERY knowledgable ford diesel Techs that hang out there more so then here in the SD forum. Cheezit and a few others there are a wealth of knowledge and should be able to help you
Oh and welcome to FTE.
Old Feb 28, 2010 | 07:43 PM
bayou barataria's Avatar
bayou barataria
If you are getting those codes for the injectors it probably is the hpop as the oil pressure powers the injectors. This is a common failing on the 6.0's.
