bolt pattern
Old Feb 28, 2010 | 06:37 PM
dpotlicker's Avatar
dpotlicker
bolt pattern
can i change my 5x5.5 bolt pattern to the 5x4.5 bolt pattern on my 91 f150
Old Mar 1, 2010 | 12:47 AM
skyfox10's Avatar
skyfox10
I would most likeyl be easiest/cheepest to use these (Wheel Adapters 5 Lug CJ Ram). Also, you might be able to take parts from the 8.8 axels in the explorers.
Why do you want to change? trying to fit some rims you have lying around?
Old Mar 1, 2010 | 09:02 PM
dpotlicker's Avatar
dpotlicker
a buddy wants to give me his 22s off his sporttrac
Old Mar 1, 2010 | 09:44 PM
skyfox10's Avatar
skyfox10
I'm assuming those are aftermarket. I can't imagine a sportrac having 22's from the factory.
It all boils down to the time & money you want to spend. Using the adapter is going to make your truck's stance a little wider, since it has to space everything out a bit. If I remember correctly, this is supposed to be a bit harder on the wheel bearings.
I thought about doing the opposite mod to my explorer since I have all sorts of rims that fit the 5.5" truck pattern. So it would be easy to swap between my truck & explorer whenever needed.
Old Mar 1, 2010 | 09:48 PM
dpotlicker's Avatar
dpotlicker
couldnt i just use the spindles and axels off of a f100 or an explorer
Old Mar 1, 2010 | 09:55 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
Actually, the 22's will have so much backspacing....the spacers will not harm anything. In fact, you may have to space them out anyways. Similar to putting 05+ Mustang wheels on an 04 or older.....if you don't use a spacer, the wheels sit too far inside.
The Explorer is not gonna work. And I'm not sure you could not find the F-100 parts for less than the cost of the spacers.
Old Mar 1, 2010 | 10:03 PM
dpotlicker's Avatar
dpotlicker
thanks i will look into that
MHammer21
Oct 5, 2012 02:12 PM
create
May 2, 2006 06:26 AM
hammerdn
Feb 25, 2005 03:00 PM
mnstang
May 30, 2004 10:01 AM
weldman
Feb 12, 2001 01:33 AM
