excursion + beach = stuck
Old Mar 1, 2010 | 09:24 AM
ZaksEx03's Avatar
ZaksEx03
i typically run at between 20-25 that wat i do in my f150 but i guesse i need to drop them down a bit. thanks for the imput
Old Mar 1, 2010 | 01:15 PM
bcrewcaptain's Avatar
bcrewcaptain
air down, air down, air down...I've run thru some nasty soft sand at the OBX in mine and even when I had the 265's had no problems...
with the 285s for beach driving I go down to 16-18 lbs...no issues at all, keep momentum if possible and keep from doing donuts..
Old Mar 1, 2010 | 01:21 PM
ZaksEx03's Avatar
ZaksEx03
haha i try not to do donuts... but ill drop my pressure down to 15 and turn my chip off and see what happens..
Old Mar 1, 2010 | 01:24 PM
Airslot's Avatar
Airslot
Good info. I took the X out at lunch and found that the auto hubs are not engaging, but everything works as it should in manual. Just another project to add to the list...
Old Mar 1, 2010 | 01:30 PM
jdadamsjr's Avatar
jdadamsjr
If you've ever ridden bikes in the sand you understand it's all about momentum and keeping on top of the sand
wheel spin will bury you,
and there's not a much better workout than trying to pull a buried bike out the soft stuff !
air down to a safe level and be ez in the turns and the speed....
a rock or root at speed without air would not be a good thing....
with E rated tires, you'd be surprised how low psi u can go with the strong sidewalls...
I usually put mine in high range not low range....
and rode round in third when I could to 'smooth out' the accelerator burst (like we should on ice )
carry a battery operated air pump or better yet an on board air supply !
and air up at pavement...
Old Mar 1, 2010 | 01:48 PM
ZaksEx03's Avatar
ZaksEx03
ya were i go out there are air stations at the entrance .
and ill try that 3rd gear on the beach(if nothing else it will role some coal)
thanks
Old Mar 1, 2010 | 01:49 PM
ZaksEx03's Avatar
ZaksEx03
ps how do i get a signature at the bottom??
Old Mar 1, 2010 | 07:09 PM
nghtrgr's Avatar
nghtrgr
Go to User CP in the upper left of the page. Believe you also have to have a certain number of post's if I remember. Here is a thread about my Ex on the beach, sorry to hear you are having a tough go at it.
https://www.ford-trucks.com/forums/8...anks-pics.html
Old Mar 1, 2010 | 07:10 PM
PhoenixRisen's Avatar
PhoenixRisen
Maybe ease up on the throttle when you start off? How does that 4x4 low work on sand? I live in mud country so I'm not sure about the sand.
Old Mar 2, 2010 | 11:28 AM
ZaksEx03's Avatar
ZaksEx03
thanks guys. and i will check out the user cp for sig.
Old Mar 3, 2010 | 07:35 AM
tacurt's Avatar
tacurt
Originally Posted by ZaksEx03
every time i take my X on the beach i bury it im letting air out and im riding on 33x12.50 nitto terra grapplers any suggestions? thanks zak
Stop taking it to the beach
Sorry, couldn't resist.
Old Mar 3, 2010 | 07:36 AM
tacurt's Avatar
tacurt
Stop taking it to the beach?
Couldn't resist.
Old Mar 3, 2010 | 11:29 AM
  #28
howler4x4's Avatar
howler4x4
X2 on testing your hubs.
Give your tranny a break and use 4-Low.
Go easy on the throttle in sand.
My take on beach tires...
Smooth tread, even bald, not a problem. Aggressive mudders will dig straight down given enough throttle. Baldies will spin but not dig anywhere as much.
It's the air pressure that makes a huge difference; when the footprint is big enough you'll float on top.
Old Mar 3, 2010 | 11:36 AM
  #29
howler4x4's Avatar
howler4x4
There is a Lock-Right locker for the Dana 50, which would be great in sand. I would NOT recommend it for the street though. In 2WD it would not be active, no problem there, but in 4WD on snow (for instance) it would be a bear to steer.
Old Mar 3, 2010 | 12:20 PM
  #30
OutlawNomad's Avatar
OutlawNomad
Originally Posted by njneer1
This would work ......
Six Door Excursion in Iceland!
Why does it look like this thing is being driven on the moon?
