Four Barrel Secondaries Question
Old Feb 28, 2010 | 03:13 PM
AbandonedBronco's Avatar
AbandonedBronco
Hi everyone,
Have the Holley 390 on my Bronco apart for a stripped fuel bowl bolt.
This time while I had it apart, I noticed that even with the primaries completely closed, the secondaries had quite a bit of travel.
As far as I know, the secondaries aren't supposed to be able to open AT ALL if the primaries are closed.
For those that know carbs, are the secondaries (on the right) in these pictures opening too much? If so, do I need to bend the arm to limit their travel?
A picture of the primaries and secondaries completely closed. A lot of travel left.
Primaries and secondaries completely closed.
These three pictures are to show how far the secondaries can open on their own with the primaries completely closed. Seems like a LOT to me.
Thoughts? Is this normal? Or are these just able to open up way too much whenever they want? The vacuum secondary actuator does keep them stable, so they don't wobble around, but I wouldn't want them to be open while I'm just cruising down the highway.
Old Feb 28, 2010 | 08:07 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The way the secondaries work is the flow thru the primaries creates a vacuum to open the secondaries, therefore, they shouldn't be able to open while just cruising. Unless the primaries are nearing peak flow, there won't be enough vacuum to pull the secondary pod open.
That's more free travel than most I've seen, but shouldn't be an issue.
Old Feb 28, 2010 | 10:35 PM
AbandonedBronco
Yeah, they're completely controlled by vacuum, but if they were completely secured by it, I don't think there'd be a need for the limiter bracket shown in picture 1. It's currently allowing the vacuum from operation to pull the secondaries further open than the primaries.
My thoughts on it, doesn't necessarily mean I'm right.
Just to be on the safe side (since that seems like it could greatly affect MPG, which have been an issue), should I bend the limiter to make sure the secondaries can't open at all when the primaries are closed?
Old Feb 28, 2010 | 11:08 PM
Harte3's Avatar
Harte3
Might try checking with the Holley Techs on that one.
Old Mar 1, 2010 | 10:39 AM
AbandonedBronco
Sent in a ticket. I'll be curious what they have to say.
Old Mar 1, 2010 | 02:04 PM
1986F150six's Avatar
1986F150six
AbandonedBronco,
I may be seeing things, but your second photograph shows what appears to be a rubber cap for a vacuum fitting [left upper side]. Is it cracked?
Old Mar 1, 2010 | 02:16 PM
AbandonedBronco
Yeah, it's got some cracks in it. I need to put some new ones on. Good eye.
Old Mar 1, 2010 | 07:57 PM
Harte3's Avatar
Harte3
Those caps just don't seem to hold up very well...gotta keep checking them.
Old Mar 2, 2010 | 10:08 AM
chrlsful's Avatar
chrlsful
My YF rebuild had a lill' sheet of directions (for a real mechanic to use). It gave measurments for almost every operation of the carb: "Push this to here, measure, return to former position, measure. Difference should be xx. Bend tab xx to achieve that measurement." U might benifit from similar proceedure if U can get those figures (from the co., as it seems U R in the process of aquiring).
my .02$
Good luck, I know YOU will get YOUR Qs answered n B back on the rd!
AbandonedBronco
May 1, 2012 12:14 PM
AbandonedBronco
18
Oct 20, 2010 11:25 PM
AbandonedBronco
Sep 19, 2010 11:11 AM
AbandonedBronco
65
Jun 14, 2010 09:12 PM
AbandonedBronco
1978 - 1996 Big Bronco
May 27, 2008 02:30 PM
