Tune up, now wont start.
Old Feb 28, 2010 | 10:01 AM
Redcoat's Avatar
Redcoat
I just tuned up my truck, replaced cap, rotor, plugs, wires, and coil. coil is a 48,000 volt coil so i could gap my plugs to .055, as per a "performance" tune i found on fullsizebronco website. After the tune up, my truck wouldnt start. i tripled checked the wires, they are all in the right spot. then, near the coil i found a loose wire going into a black piece of plastic attached to the coil mount (ground?). so i wiggled it and it broke off. to see if the truck would run, i just clamped this wire right onto the mount. see picture: truck on Flickr - Photo Sharing!
it worked, the truck ran, i revved in neutral it ran good. i put it in reverse backed up about a foot and the truck died and wont start. the starter still runs, but when i put the key to on i dont hear the fuel pump. i checked the fuses in the fuse box they are all fine. what have i done? whats wrong?
truck is 1996 f-250 5.8L
thanks
Old Feb 28, 2010 | 10:49 AM
pete17c's Avatar
pete17c
I think the wire is supposed to connect to the 'module' just below where you've 'clamped' it .. mines older and the 'module' looks different, but have a look ..
Old Feb 28, 2010 | 10:58 AM
subford's Avatar
subford
Un-clamp it!!!
That wire goes to the radio cap and you just shorted the Ignition system to ground.
You also now have a bad fuse #22 a 20 Amp Fuse in your engine compartment fuse box.
Old Feb 28, 2010 | 11:58 AM
Redcoat's Avatar
Redcoat
thank you for replying, I do indeed have that blown fuse, im going to go buy a new one. i unclamped that wire, but what should i do with it now? whats that little black part called and where would i find one?
Old Feb 28, 2010 | 12:09 PM
subford's Avatar
subford
Any auto parts store should have the radio capacitor (condenser as they were called in the 1920's).
Just leave the wire off and insulated from any metal. The truck should run OK but may have some radio noise.
Old Feb 28, 2010 | 02:04 PM
Redcoat's Avatar
Redcoat
I replaced the fuse and the truck runs fine/good now, and i put a wire nut on what wire. my radio seems ok.
thanks for your help
Old Feb 28, 2010 | 06:09 PM
pete17c's Avatar
pete17c
condenser .. that's what I was gonna call it (searched for parts w/ 'condenser' and only got the part for A/C) .. just didn't want to be wrong (wasn't 100%) and lead redcoat astray ..
might be OK with certain stations .. might get noise on different frequencies .. (especially on AM) .. radio might have some background whine, changing pitch with RPM ..
Mitchapalooza
1997 - 2003 F150
Jan 21, 2017 07:13 PM
tpdaniels
92
Dec 23, 2016 08:56 PM
billymfh
18
Mar 13, 2013 04:20 PM
Canty
Mar 11, 2013 12:29 AM
93XLT150
Feb 15, 2011 05:40 PM
