1974 Ford F-100 Ranger
Hello, this is my first post. I was looking on Craigslist for a trailer, and ended up buying my first Ford truck. I saw this for $750 and couldn't pass it up. I'm currently rebuilding a 1977 VW Camper, so I'm planning on just fixing it up enough to pass inspection and run reliably so I can use it for hauling and backup transportation. I'm sure I won't stop there though.
Anyway. My plan is to start by rebuilding the carb, replace battery, belts, hoses, and any rubber fuel lines. I need to get the turn signals working. I'd like to get rid of the radiator overflow tank pictured below. This is my first water-cooled project, but I'm pretty sure it's not stock. hehe. I can't wait to dig in to that 390 V8.
I'm sure I'll have lots of questions as I go forward. Enough chatter, here are some pics:
Thanks for looking,
BillyMFH
Thanks for looking,
BillyMFH
what are you talking about get rid of the rad over flow tank... that is the rarest over flow tank ever made!!! there was only one ever installed in a 74 f100 ranger... and your just gonna toss it in the garbage like yesterdays trash!?!?!?!?!?!?!?!? i cant belive you!!!
just kidding... i dont think that is stock...
welcome to FTE.... theres lots of info here... search for your questions first... if nuthing comes up ask away!!! theres a few other v dub lovers on here... myself one of them... im looking for money to do a 74 supper bettle but so far thats not going to well... since my truck really has my heart right now....
It's the windshield washer reservoir: D1TZ17618B Fits: 1971/79 F100/350's and 1978/79 Bronco's.
Remove it, you will no longer have w/shield washers! The w/shield washer pump is plainly visible in the pic as it fits into the reservoir at the front lower corner.
The radiator overflow tank (D1TZ8A080B) was only available on 1971/74 F100/350's with the 240 I-6, and mounts on the passenger side.
It looks nothing like the w/shield washer reservoir.
Thats cool, looks like a nice project truck you got there! What is the back story on the truck? Where abouts are you located? Welcome, and let me warn you theses thrucks are a lot of fun and become very addicting to work on and enjoy (most of the time, haha). I sometimes wonder, who ownes who, or better yet, who ownes the wallet!! Anyhow,.....
Just kidding, they are fun old great trucks to enjoy, wheather you want to jack it up to the moon, drop it on the floor, or keep it stock and original looking, its all good, and it's fun to make it to fit your needs and desirable looks.
Now your an FTE brother, and don't forget to join your local chapter! Its a great way to meet others in your area who have the same interests, and possible parts you may need!! SO,... enjoy, and enough of my babble, and welcome again!!
PS: Just so you know, we LOVE truck pictures! It's like **** around this site!
It's "stock" all right, but it's not a radiator overflow tank.
I'm in Independence, MO. Just joined the MO chapter.
I'm mostly going to just get it running well for now. I need it for hauling stuff around. I was actually trying to find a trailer on Craigslist when that chrome and steel caught my eye. It reminds me of a 60's Ford my dad had when I was growing up. I used to love going to the dump with him in it. My kids are already excited about riding around in it.
1976: Power front disc brakes introduced for 4WD's. 1959/75 4WD's all came with front/rear drum brakes.
F100/150's have 5 lug wheels on a 5.50" bolt circle / F250's have 8 lug wheels on a 6.50" bolt circle.
You'll need to find a 1976 F100 4WD, or 1976/79 F150 4WD (except Super Cab), swap the entire front driving axle/suspension/disc brakes/master cylinder/prop valve, cuz nothing else will fit.
F100's were not available w/4WD after 1976.
Awesome find, especially all original and for only $750! The body looks to be pretty straight and clean and a 390 to boot! On the truck is an original optional Ford topper. My guess is that it's been on the truck since 1974. You have the "deluxe" topper model that included the sliding windows, bright alum trim, interior light, and roof vent. It even looks like it still has the 4 seasons compass emblems on them, which is rare. Most have been removed. I'm not sure if you will find the rear door alone but it you keep looking, you will eventually find another topper and can use it as a donor. I seem them around here for $75-$100. I have restored a couple of the toppers and pretty simple. They were produced in the wimbledon white and depending upon how picky you are, you can either have it professionally painted at a auto shop or you can use a good exterior paint and have it matched. Need to do some scrubbing and sanding first. Great find and I would have snatched that up in a minute!
Power Assist P/S was all that was available for 1973/75 F100 4WD's, 1975 F150 4WD's. Uses a separate P/S control valve and P/S ram cylinder.
The manual steering gearbox is used, as it has nothing to do with Power Assist:
Two long P/S hoses, pressure & return, route from the pump to the control valve. Two short P/S hoses, pressure & return, route from the control valve to the ram cylinder.
All the parts are obsolete .. very expensive when found. The steering linkage and Pitman Arm are specific to Power Assist.
So, to add P/S, you'll have to use 1976 F100 4WD or 1976/79 F150 4WD Ford/Saginaw integral P/S, that will not simply just bolt right on.
Modifications are required to get the integral P/S to work.
