1995 Ranger Check Engine Light Problem
Old Feb 28, 2010 | 09:36 AM
ski1491's Avatar
ski1491
I have a 1995 Ranger with a 4cyl and 5peed that has a check engine light I can't seem to ger read. I have an OB II port in the cab, but three auto parts stores and a friend can't read it. I checked all the fuzes, no problem there. Before I go to the dealer looking for some suggestions. It runs fine also. Thanks in advance for any help
Old Feb 28, 2010 | 10:05 AM
Rockledge's Avatar
Rockledge
All I can say is, keep looking around for a "bare bones" OBD-II code reader:
Ford Truck Enthusiasts Forums - View Single Post - 1995 ranger no start
Old Feb 28, 2010 | 02:02 PM
antony25's Avatar
antony25
The '95 ranger is not ODB II. You must use an EECIV scanner or manually pull codes with the under hood connector.
Old Mar 1, 2010 | 09:24 AM
ski1491's Avatar
ski1491
OB-II Connector
I do have an OB-II connector in the cab by the parking brake and there is no connector under the hood. I had seen some discussion a year or two ago discussing how they cut in OB-II in "95", but there was problems reading the codes. I was looking to see if anyone else had run into this and how they overcame it. Thanks much
Old Mar 1, 2010 | 01:44 PM
aquanaut20's Avatar
aquanaut20
The OBDII port under the dash is a dummy on the 95, you have a test port connection in front of the brake booster, under the hood.
Old Mar 1, 2010 | 04:52 PM
87 XLT's Avatar
87 XLT
This is what you're looking for plus the single wire conector
http://www.superhighoutput.com/tech_view.php?id=5
I had to fish around for it the first time i pulled codes on my 87. It was buried & hanging at the end of it's wires
Old Mar 2, 2010 | 12:19 PM
ski1491's Avatar
ski1491
Still No connector
Been all over the area around the power booster and no connector. Also looked at the connector under the hood and there is wiring going to that connector. I took some pictures of the brake booster area, but I'm not sure I can post them. Again, thanks for the help andf advice
Old Mar 2, 2010 | 12:29 PM
aquanaut20's Avatar
aquanaut20
an alternate location for that connector would be near the blower motor on passenger side(<95)
Old Mar 2, 2010 | 12:42 PM
87 XLT's Avatar
87 XLT
Yep, thats where it is on my 87. Ford had a much better idea on my 95 Taurus. It was velcroed to the passenger side firewall.
BaymaxNo1
Jun 9, 2015 05:43 AM
boaterdude83
Jan 13, 2013 02:43 PM
JaysRanger
May 7, 2012 01:22 AM
Fomhoire
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
39
Jul 13, 2011 02:17 AM
97 ranger 1
Jun 26, 2005 07:04 PM
