Sponsored by: Auxito
GAUGE LIGHTS OUT
Old Feb 27, 2010 | 11:38 PM
garyodell's Avatar
garyodell
Angry GAUGE LIGHTS OUT
INSTUMENT LIGHTS OUT. PULLED CLUSTER REPLACED ALL BULBS FUSE 18 HAS 12 VOLTS WHEN LIGHT SWITCH IS ON IS IT THE DIMMER SWITCH ANY IDEAS ON HOW TO TEST THIS MUCH APPRECIATED
Old Feb 28, 2010 | 03:59 PM
garyodell's Avatar
garyodell
Smile PROBLEM SOLVED
I WAS ABLE TO FIX THE PROBLEM.IT WAS IN THE ACTUAL DIMMER PART OF THE SWITCH.ON THE SMALLER PLUG ON THE BACK OF THE SWITCH I HAD 12 VOLTS ON THE INPUT DK BLU/WHT WIRE.THE OUTPUT TO DASH LIGHTS IS THE LT BLU/RED WIRE.THERE WAS NO VOLTAGE THERE.SO INSTEAD OF BUYING A NEW $70.00 SWITCH I JUMPERED THE TWO WIRES.THIS MEANS I WILL NOT BE ABLE DIM DASH LIGHTS. NO BIG DEAL THANKS TO THE WIRING DIAGRAM IN MY TRUSTY HAYNES MANUAL
