Crank pulley Removal
Old Feb 27, 2010 | 03:00 PM
truckerboy's Avatar
truckerboy
I have an 81 F100 that has a 300 six and i am rebuilding it. I need to find out how to get the crankshaft pulley off so that i can acess the timing gears. The repair manuel that i have says to put the truck in gear to hold the crank in place, but that isnt working, the motor still turns a little and the bolt isnt comming loose. Has anyone out there had this problem in this type truck before? and if so, how did you fix it?
thanks in advance. There are pictures in my album labled Blakhawk
truckerboy's Avatar
truckerboy
Is it possible to remave the crank with the motor in the truck??
Old Feb 28, 2010 | 11:34 PM
F150xlt's Avatar
F150xlt
You can wedge a pry bar between the flywheel teeth and transmission bell housing to keep the crankshaft from turning.
Old Feb 28, 2010 | 11:43 PM
truckerboy's Avatar
truckerboy
Will that damage the flywheel? or would it be ok to pull the oil pan and take the crank out with the pulley still on it?
donthekawguy
Jul 30, 2016 07:35 PM
henryfrick
May 22, 2016 05:26 PM
mudboggin3
Nov 8, 2013 10:47 PM
Uncle Ethan
Nov 6, 2011 06:04 PM
JefflovesF250s
Dec 2, 2004 05:25 PM
