Different Fuel Filter Mount
Old Feb 27, 2010 | 05:54 AM
Amorabito893's Avatar
Amorabito893
I just bought myself a 1984 F250 6.9 turbo and I have a couple questions.
The engine is supposedly from an 86 e series with about 150000 miles on it. I bought a new fuel filter mount to incorporate a water separator into the fuel filter. However when I went to mount it I discovered that the fuel filter mounts to the driver's side of the engine and is made from one piece of cast aluminum. This seems to be different from anything I have found on this forum.
Also the ATS turbo seems to be the 085 series looking at the airbox, but the turbo itself looks like the newer model with the two chamber turbine housing. Has anyone heard of making a hybrid system??
The truck has an Isspro tach mounted into the center of the stock instrument panel and I was wondering what I would need to get it up and running on the transplanted motor.
I think some of the issues maybe due to it being a van motor so if anyone has any insight I would appreciate it. I will try to post pics if I can figure out how to do it from work.
Thanks
Anthony
Old Feb 27, 2010 | 06:27 AM
rckslash2010's Avatar
rckslash2010
[quote=Amorabito893;8571725]I just bought myself a 1984 F250 6.9 turbo and I have a couple questions.
The fuel filters on the 6.9 are located where your talking about. The 7.3 fuel filter is located on the passenger side of the engine compartment, above the valve cover. People have converted their 6.9 fuel filter setup, to the one that they use on the 7.3
Old Feb 27, 2010 | 07:30 AM
Amorabito893
These are the pics. Thanks
Old Feb 27, 2010 | 07:32 AM
Amorabito893
Old Feb 27, 2010 | 09:50 AM
starmilt's Avatar
starmilt
That still has the origanal fuel line with the heator but is different from a pickup. It must be the one from the van. If it still has the original water seperater it on the firewall to the drivers side of the brake booster.
