Explorer radius arm bushings
Old Jan 21, 2003 | 07:51 AM
Irv's Avatar
Irv
Where can I purchase improved radius arm bushings for my 1991 Explorer. These are the rear rubber bushings. They don't last long here in Colorado....Irv
Old Jan 22, 2003 | 07:19 PM
Dialtone's Avatar
Dialtone
I ordered a set of the red poly from JC Whitney online. Price was reasonble and shipment was prompt. They have been on for about 2 years now and seem to perform well. Only time will tell however.
Dialtone
Old Jan 23, 2003 | 05:09 AM
marragtop's Avatar
marragtop
Is this the bushing that sits by the cat converter?? If so, what's involved with replacing it??
thanks
Old Jan 23, 2003 | 11:31 AM
Dialtone's Avatar
Dialtone
Assuming they have not been replaced before, the most difficult part of the task is removing the cross frame support at rear of radius arm. The supports are attached to frame runners with both bolts AND rivets. To remove, the rivets must be chiseled/ground or torched off, then replaced with bolts. If inspection reveals previous work and all bolts are present, the job is not too difficult and requires about 1-1/2 hours per side, or less if air tools are available. Before removing, block the front wheels so they cannot move foreward, and try not to lift the vehicle too much. This makes re-assembly much easier and keeps the radius arm in relative position to allow easier re-assembly. You may need a small floor jack to help lift radius arm back into position for reassembly. Check for presence of a heat shield on the front half of the right side bushing adjacent to the cat converter. If not present, get one and install it now as it deflects cat heat from bushing.
Dialtone
Old Jan 23, 2003 | 08:35 PM
Opera House Works's Avatar
Opera House Works
I got mine at Autozone for about $15 each. I didn't take off the cross member. Pulled the wheel forward an inch after removing sway bar frame bushings. Cut the old bushing off, slit the new bushing to the center and slid the new one on. Crude but it has lasted 70K even with large chunks of metal missing from the mount. Only real work is getting the nut off if you don't have an air wrench.
Old Jan 24, 2003 | 04:46 PM
Irv's Avatar
Irv
Thumbs up Explorer radius arm bushings
Thanks to all responders for the info on the bushings
