Do I need a new rear end(?)
Old Jan 24, 2003 | 04:58 PM
FallPheasants's Avatar
FallPheasants
Greetings!....I have a 95, XLT Explorer, axle code 45 (410 rear end(?) , 95K miles, new brakes, rotors, tires.......for the past month and a half a soft "rubbing" sound has been coming from the vehicle when the vehicle drive line is straight or curving to the left. When I curve to the right (takes less than 20 degrees right on the steering wheel) the rub stops.......after the steering wheel straightens, the rub starts again...........mechanics at a national car repair chain (not named) stated its coming from the rear end and the rear end will need replaced.......I thought it was a wheel bearing or CV joint possibly. Would turning the wheel gently curving to the right have any impact on the rear end noise(?) They stated it's because it shifts the weight on the rear end so it's not bearing much load, and that's why the noise stops. I'm going for a few more opinions, but I was hoping someone could offer some insight or advice. Thanks for your time!
