Banjo bolt
Old Feb 26, 2010 | 08:32 PM
coopford's Avatar
coopford
Banjo bolt
I am trying to fix a fuel leak on a 1997 7.3.
It looks like it is in the area of the banjo bolt. Do I need to replace the bolt and washers or just the washers? Do the washers come in a kit or do I need to purchase them seperately? Is there 2 washers?
Thanks in advance!
Old Feb 26, 2010 | 08:35 PM
97-psd's Avatar
97-psd
I believe it is just one gasket, it is metal, you may try just cleaning it and re-using it,
Old Feb 26, 2010 | 09:11 PM
Hussler's Avatar
Hussler
There is a washer on each side of the banjo bolt. Most likely the fuel pump is leaking out the weep hole (like a water pump). If so you need to replace the pump. It's hard to see the leak because it's just below and to the left (passenger side) on the pump body.
If you purchase a new pump you also need to get new washers. They don't come with the fuel pump. You can get them at a Ford or International dealer.
Old Feb 26, 2010 | 10:26 PM
jleal_21's Avatar
jleal_21
mine has a leak that i noticed this week while changing the oil. mine is leaking off to the passenger side of the truck but the engine valley is pretty clean. last time i changed my fuel pump was about a year ago and maybe mine might be leaking from the banjo bolt gasket cuz i don't remember if it came with the fuel pump or not.
Old Feb 27, 2010 | 06:52 AM
coopford's Avatar
coopford
Would you recommend buying a fuel pump at ford or going through the local parts house?
Old Feb 27, 2010 | 07:21 AM
yoslick's Avatar
yoslick
Before you do anything I'd try cleaning the valley spotless, idle up the truck and get in there with an inspection mirror and bright light and see whats going on, could be as simple as the bolt needing a little snugging up..
Old Mar 2, 2010 | 09:04 PM
fixitman1310's Avatar
fixitman1310
i am replacing my pump as well. is there a special wrench i can get to remove the
banjo bolt without moving the turbo. thanx guys
f250 ps 143,000 f350 ps 276,000 steve in n.carolina
Old Mar 2, 2010 | 09:07 PM
Red97350's Avatar
Red97350
Just a 1 1/4" wrench should work for the banjo bolt.
Red
Old Mar 2, 2010 | 09:34 PM
Ken_C's Avatar
Ken_C
I reused the gasket in mine. if you end up replacing the fuel pump do yourself a favor and check fit the old banjo bolt into the new pump. make sure it goes all the way in and back out without hanging up at all. do this before you bolt the new pump into the valley. unless its damaged you shouldnt need to replace the gasket its copper iirc. shouldnt need to remove the turbo either. just really short turns with a 1-1/4" box end wrench. and try not to drop anything down the hole the old pump came out of. things like the push rod or hold down bolts turn the engine by hand until the pump push rod is at top dead center might be helpful.
Old Mar 5, 2010 | 09:20 AM
coopford's Avatar
coopford
Thanks for all the help! It was the fuelpump leaking.
mudhole
May 22, 2024 12:23 PM
Brnfree
Apr 25, 2019 03:38 PM
therigwelder
Oct 2, 2016 12:34 AM
jacob_powerhouse
Sep 22, 2016 08:58 PM
Jesser02EX
Dec 6, 2015 08:54 AM
