In a real pinch
Old Feb 26, 2010 | 06:49 AM
RDJ184's Avatar
RDJ184
In a real pinch
sorry guys I am late for work can someopne please help
have looked in tech folder and running out of time 2005 6.0 starts for a second and dies and only a second it tries but just cant light up all the way
Old Feb 26, 2010 | 07:09 AM
bismic's Avatar
bismic
Getting fuel to the secondary fuel filter?
Do you have any aftermarket stuff (security system, tuner)? How about gauges (like fuel pressure).
I assume you have drained the primary fuel filter to look at the fuel quality (ie any gelling). Also, filter changes recent? What filters did you use?
Old Feb 26, 2010 | 07:13 AM
RDJ184's Avatar
RDJ184
ues napa filters live in florida never had a prob with gelling
RDJ184's Avatar
RDJ184
and completly stock
Old Feb 26, 2010 | 07:20 AM
teppler's Avatar
teppler
Just thinking when my FICA went out it had the same symptoms BUT only in freezing weather. Just a thought.
Old Feb 26, 2010 | 07:22 AM
bismic's Avatar
bismic
May not have anything to do with it, but Ford warns that aftermarket filters can plug a lot more quickly than the OEM (Racor, International, or Motorcraft). They can also swell with water and plug off.
Make sure your fuel pump is pumping (pulling the secondary fuel filter and cranking) - watch for fuel flow and the fuel bowl should be essentially full when you pull the filter. Two person job, you should also pull a fuse to do the test (just for safety). It is all described in the "troubleshooting a no-start condition" - in the Tech Folder.
Sorry - I am late for work also - hopefully others can jump in w/ more if needed.
Old Feb 26, 2010 | 07:54 AM
RDJ184's Avatar
RDJ184
running to get new filters will brb
Old Feb 26, 2010 | 08:38 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Are you still under warranty Randy?
Old Feb 26, 2010 | 08:49 AM
69cj's Avatar
69cj
Correct me if I'm wrong but the pump will run KoEo without cranking. Safer that way and should fill 2ndary bowl.
RDJ184's Avatar
RDJ184
no warrenty new filters insatlled ..same thing kicks and bucks but will just not fire up?
It trys to
Old Feb 26, 2010 | 08:53 AM
RDJ184's Avatar
RDJ184
and hey Steve how you been?
Old Feb 26, 2010 | 08:58 AM
69cj's Avatar
69cj
If the batteries are good I think it's time to check the fuses and then the FICM voltage.
Old Feb 26, 2010 | 09:00 AM
SteveBricks
FTE Emeritus
Doing well Randy...long time no see
It would help a lot if you could get the codes read...
Old Feb 26, 2010 | 09:01 AM
RDJ184's Avatar
RDJ184
cranks over fine and tries to start it just wont ran fine yesturday
Old Feb 26, 2010 | 09:02 AM
RDJ184's Avatar
RDJ184
yes it would steve but cant get it any where
