Exhaust hardware
Old Feb 25, 2010 | 08:02 PM
7283-F250's Avatar
7283-F250
Exhaust hardware
Have to install a new cat on my car (4 cil). Main question is can I use stainless bolts on the exhaust?
Cat converter basically bolts directly to the exhaust manifold. At the other end under the motor the cat converter pipe hooks to the flex pipe. Can I use stainless on both ends?
Also the new aftermarket cat converter is smaller diameter than the stock cat converter so the bracket holding the cat to the motor dose not fit. The only thing holding the cat on is 3 bolts in the head end and a bracket at the flex end.
Thank you
Old Feb 26, 2010 | 10:34 AM
KhanTyranitar's Avatar
KhanTyranitar
You can use stainless, but you have to make sure it is the right kind of stainless. You can't just use regular hardware store stainless bolts, you need heat treated bolts made for exhaust.
What cheap brand cat did you use?
Old Feb 28, 2010 | 07:47 PM
7283-F250's Avatar
7283-F250
Picked up a Magnaflow off eBay. $222 vs over $700 for OEM. The car would never get on the road if I had to go OEM.
and thanks for the info. There is a bolt specialty place near the house I was planning on getting the bolts from. Knowing what to ask for helps a lot.
