460 oil pressure
Old Feb 25, 2010 | 06:42 PM
mike1589's Avatar
mike1589
460 oil pressure
Just hooked up a new oil pressure guage the other day, and when i first start it when its cold the oil pressures about where it should be, but once it warms up it goes down to about 10-12 at idle, seems really low to me is this ok?
Old Feb 26, 2010 | 10:11 AM
mark a.'s Avatar
mark a.
Is it a mechanical gage or electric ?
Old Feb 26, 2010 | 12:03 PM
mike1589's Avatar
mike1589
its mechanical
Old Feb 26, 2010 | 01:33 PM
mark a.'s Avatar
mark a.
Assuming you are not using a Fram filter, I wouldn't worry about it yet as long as it's not knocking.
Old Feb 26, 2010 | 02:12 PM
monsterbaby's Avatar
monsterbaby
Does it come right up as soon as you touch the throttle? if so your probably getting some wear in the bearings but as stated probably not enough to worry about yet. If it stays low, then yeah you need to get into it.
Old Mar 14, 2010 | 03:17 PM
77_150_460's Avatar
77_150_460
Mind does the same when warm according to my mechanical gauge - 10-15 psi at idle (mine is a bit low) but right up to 40-ish when cruising down the road.
