Tranny cooler
Old Jan 20, 2003 | 10:52 PM
krazdndenver's Avatar
krazdndenver
Question Tranny cooler
I got a radiator out of a 73 for automatic transmission, I put an AOD in the 72. The inlet and out let are on the bottom of the radiator and I do not know which is which, please help.
Thanks
Robert
72 F-100 Ranger XLT W 86 5.0L W/ AOD
www.geocities.com/krazdndenver
Old Jan 20, 2003 | 11:04 PM
BB's Avatar
BB
Tranny cooler
The inlet is the fitting closest to the bottom radiator hose.
Barry
Old Jan 22, 2003 | 06:10 PM
Ecartman's Avatar
Ecartman
Tranny cooler
Why does it matter? I was told as long as you get the out from the tranny to the radiator first, then to any aux cooler you may have, it's right. What happens if you get the in/out backwards?
Old Jan 22, 2003 | 08:52 PM
BB's Avatar
BB
Tranny cooler
I knew somebody was gonna ask that question!
Honestly, I don't know how much but the cooler runs more efficiently hooked up that way. It has to do with the direction of flow in the cooler vs. the direction of flow in the radiator tank. Hooked up that way they run in opposite directions. This reduces the self-heating effect on the cooler, you want the hottest part of the cooler downstream and the coolest part upstream. That way when the cooler gives up heat in the radiator, it doesn't pass as much heat back over the cooler again because the hottest part is in the rear. Another way to think of it is the tranny fluid "sees" cooler radiator flow past it. I hope that makes sense, I had to visualize it for quite a while. All vehicles are plumbed this way. And yes, you always want to put an add-on cooler in the return line to the tranny.
Barry
Old Jan 23, 2003 | 11:56 PM
krazdndenver
Tranny cooler
This makes great sense, but now I need to know which is the in & out of the AOD. Can someone help me with this, I was planning on tring to plum the tranny this weekend?
Robert
Old Jan 24, 2003 | 12:49 AM
BB's Avatar
BB
Tranny cooler
The return line is the fitting closest to the rear of the tranny.
Barry
Old Jan 24, 2003 | 10:10 AM
krazdndenver
Tranny cooler
Thanks for the info, now I can get this plumed up and mabey even fire it up this weekend. It has been almost a year since I rebuilt that engine and put it in the truck
Robert
Old Jan 25, 2003 | 05:38 PM
Ecartman's Avatar
Ecartman
I still don't get it, but mine's backward. I'm going to change it.
...and yes, out is at the front of the tranny ( on a C6 anyway ) closest to the pump. Return is to the rear.
krazdndenver
Feb 5, 2004 06:56 PM
krazdndenver
Oct 4, 2003 04:07 AM
krazdndenver
Nov 29, 2002 08:25 PM
krazdndenver
Nov 19, 2002 06:30 PM
krazdndenver
Sep 17, 2002 09:16 PM
