Sponsored by: Real Truck
2003 V-10 Problems?
Old Feb 24, 2010 | 07:41 PM
jgib's Avatar
jgib
2003 V-10 Problems?
I have a 2003 with the v10 in it and am having problems with it that the dealer hasn't been able to fix, was hoping someone might know something.
The truck runs fine when cold and just started. After the truck gets hot and works under a load for awhile, after plowing snow, it will not gain any power. It ideals fine but as soon as you try to give it any power, even in neutral, it just falls on its face spudders and pops. If you shut the truck off for even just a few minutes it will run fine again for awhile.
We have replace most of the fuel system, pump, rails, not sure what else. Does anyone have any ideas?
Old Feb 25, 2010 | 10:02 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Did they ever check the fuel PRESSURE when it's doing this, or are they just throwing parts at it?
Clean the MAF. If they have a diagnostics setup, check MAF function and make sure it's actually reading correctly.
Old Feb 25, 2010 | 03:13 PM
mwsF250's Avatar
mwsF250
As Krewat alluded to, are they doing "fact based" analysis or just throwing parts?
Based on just the minimal problem description here, I'd have also been thinking about a faulty electronic sensor that was sending errant signals when it got hot. Like the TPS or a coolant temp sensor....
But to summarize, not a "common" issue with a known common cause. It will take a scientific approach to determine your root cause.
And unfortunately, some dealers do NOT invest in skilled/knowledgable/intelligent technicians. You may need a better doctor.
CliffDarnell
Oct 15, 2012 04:01 AM
grimey4life
Modular V10 (6.8l)
Mar 3, 2011 02:01 PM
Sandab2
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 8, 2008 01:35 AM
WYATT1
Jan 11, 2008 04:24 PM
