MII air baged
Old Feb 24, 2010 | 04:05 PM
rbig1's Avatar
rbig1
MII air baged
has any one air bagged a 55 f100 talked to heid today and they said there is not enough room for bags on the MII front end. there is around a inch of clearance betweeen the frame and spring. ax racer i know your opinion....
Old Feb 24, 2010 | 06:28 PM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
I have mine bagged!!! I really dont understand your question?
Old Feb 24, 2010 | 06:48 PM
SunDown's Avatar
SunDown
bagging a MII is no different than bagging anything else really. You need to come hang with us this spring or summer. We can walk you through it plus we are local!
My 55 will be bagged this spring! but not with a MII.... Dont bother with Ax, he'd just want to autocross it anyway
Old Feb 24, 2010 | 07:09 PM
rbig1's Avatar
rbig1
i was hoping you guys would post. i was going to buy after market upper and lower arms. then heidits said there wasnt enough clearance between stock spring and frame. as air bag is wider. did you have a clearance problem. it looks like i have an inch between spring and frame.
Old Feb 24, 2010 | 07:11 PM
Hammer53's Avatar
Hammer53
Are you asking about an stock MII crossmember or an aftermarket crossmember?
I have a Fatman's crossmember with shockwaves front with no issues.
Old Feb 24, 2010 | 07:17 PM
rbig1's Avatar
rbig1
it a heidts crossmember with stock arms and i was going to up date the arms and change to air bags
Old Feb 24, 2010 | 07:50 PM
rtcalabrojr
Darksider
I bought my Mii crossmember from Full Tilt streetrods. I went back to them and bought there upper and lower control arms for airbags. I told him what bags i had and they supplied what i needed. I do not see any clearance issues for me. Look in my link and look at the pics of the front end. Hope that helps!!!! I still have not finished the front shock mounts are the rear ones either. I just got the motor and trans in the frame last weekend. I pulled both so i can finish weld everything and paint the frame.
Old Feb 24, 2010 | 08:05 PM
rbig1's Avatar
rbig1
well i thought a MII was a MII i wonder if some one else arms would work with heidts crossmember
Old Feb 24, 2010 | 08:16 PM
rtcalabrojr
Darksider
I would call them and ask, them i mean Full tilt.
Full Tilt Street Rods - Mustang II Front Suspensions, Hot Rod Suspension kits and More!
Old Feb 24, 2010 | 08:23 PM
SunDown's Avatar
SunDown
I dont know this for sure since I dont have a MII, but it seems to me that I read on here once that these MII aftermarket companies all make the spread between the ends different widths. So you *have* to buy thier arms. Best thing to do is listen to Roger, give these full tilt guys a call and tell em the situation and who makes the crossmemeber, Id be willing to bet that if they dont have a set of arms that will fit right now that theyd make a set for you that will match the width, not to mention the length so you can have you room for the bags.
Worse comes to worse, we have a guy here in Des Moines that should be able to make you a set to your liking.
Old Feb 24, 2010 | 08:50 PM
rbig1's Avatar
rbig1
well i emailed both of them the only thing that worries me is. i bought my 4-bar rear from full tilt and none of the bolt were long enough to work. if that happened again i would blow a gasket.
Old Feb 25, 2010 | 04:11 PM
rbig1's Avatar
rbig1
well i ordered them from full tilt. they said there is no problem fit right on.have to put a 5/8 spacer under rack then have to cut bag spacer to ride height. and weld spacers on arm holes all for 600. now how do i make myself go out in cold shop
Old Feb 25, 2010 | 04:12 PM
rtcalabrojr
Darksider
I have always delt with Clay the owner. He always helped me out and i always got what i ordered. Did you call on the bolt issue you had?
Old Feb 25, 2010 | 04:14 PM
rtcalabrojr
Darksider
It sounds like the same kit i just bolt!! Cool!! You will be happy. What bags are you using in the front?
Old Feb 25, 2010 | 05:27 PM
rbig1's Avatar
rbig1
i emailed and talked with him. never offered to send diff bolts so i told him id get them my self. emailed a couple of questions the answers were short like go for it well as far as air bags go 2600# the only scary part is airbagit had trouble with one on the rear they charged me for a replacement thats what you get for not researching the company. never happen again.
