Spark Advance Problem
I have a '94 T-Bird with the 4.6 L V-8. It has developed a horrible stumble whenever I mash the pedal suddenly. If I ease into the pedal slowly though, it seems to accelerate nicely. I've also noticed that the engine pings severely on anything but super unleaded.
The engine check light comes on periodically. AutoTap reads the code as either "Bank 1 Lean Condition" or "Bank 2 Lean Condition". I monitored several sensors and happened to notice that my spark advance runs 22.5 degrees at idle and then drops to exactly 20 degrees at all engine rpm above idle. Something seems to removing advance instead of adding it at high rpm.
Given the pinging and acceleration problems, it seems pretty clear that the spark advance is hosed - but what controls it? Is there some sensor that sets advance or is that handled by the engine computer based on many variables?
I'm hoping this is a common 4.6 issue that someone can enlighten me on. Any help is much appreciated.
Thanks,
It sounds like your MAF sensor may be dirty and need to be cleaned. The hesitation and pinging are very common signs of that.
That was before I noticed the frozen spark advance today. Also, The MAF voltage and flow readings do vary consistently with rpm as if it's reading something real, though I don't know what numbers it should be recording.
Might there be some other bad sensor that's tricking the cpu into mis-adjusting the spark advance?
Bank 1or bank 2 lean can be the following( maf,02 sensors ,leaky intake o-rings, TPS sensor,CMP sensor ,CKP sensor,)
If you have the manual for this vehicle chk the the resistance values for the 02 sensors first or replace them.
Just my .02
Rich
My approach to this would be the o2 sensors first, if there input values are wrong .
I don't have an 4.6 l only a 5.4 l but engine controls are they same!
Rich
Clean the MAF with something besides alcohol, like brake cleaner. Then, disconnect the battery and leave it off for an hour. Reconnect the battery and test-drive.
Stumbling on acceleration is usually the MAF. Using an Autotap, it usually said either Bank 1 or Bank 2 lean.
The timing is all wrong because the computer goes into open loop, because it has no idea what's going on.
CHECK THE THROTTLE POSITION SENSOR TOO! However, if you don't have a K&N filter, I think the MAF is bad.
art k.
