1994 FORD RANGER TRANMISSION
i need a new clutch in my 1994 ford ranger with a 4 banger, 4 speed with over drive, when i floor the gas it feels like its only using 20% of its power? The clutch is sliping i guess.
How do you change a clutch? where can i buy the clutch kit for cheap? how much would it cost for a mechanic to replace?
Your description is sort of vague. When you floor the gas pedal and the engine speed increases (tach shows revs going up) but the truck`s speed does not increase then the clutch is slipping.
Try rockauto.com for a clutch kit they have a great website, quality parts, good prices and fast shipping. Also try 1ATony from the list of sponsors.
Don`t know how much a shop would charge for the job.
and you should repost in the ranger mazda B forum. you will get more action there
the thing on the firewall is the master cylinder. if the master is losing fluid look along the firewall for the leak and look inside the cab above the pedal. if you cant find a leak there, it is prob the slave. the slave is internal and the tranny needs to be dropped to change it.
+1 on doing everything. i will answer your next question in advenace. the slave cylinders are the weak part of this transmission sytem, replace it with a good one. the other parts you want are clutch, pressure plate, pilot bearing and either tun or replace the flywheel. parts=$300. Labor $300-$500
make sure you have fluid in your tranny. there are plugs at the top of the tranny that can leak. on the drivers side there is a drain and filler plug pull out the filler plug and you should be able to stick your finder in it and feel fluid. you only use mercon or mercon V atf
