vin request
Old Feb 24, 2010 | 01:29 PM
thatsrealnice's Avatar
thatsrealnice
vin request
hey guys if someone would be so kind to break down my vin info for me, thanks in advance.
X26SKCE9493
Warranty plate
155 BR X261 DFM A 24J
Old Feb 24, 2010 | 01:58 PM
thatsrealnice
4 speed transmission issue
having some other problems now. i thought it was just because i don't have a bed and no weight on the back end that it was just spinning on the ice and snow, but i don't think the transmission is engaging. i put it into reverse and try to back up and the tires don't spin or anything, and then i put it into 2nd and try to go forward, and same thing. it was fine a couple weeks ago, maybe someone could let me know what might be the problem, thanks so much.
Old Feb 24, 2010 | 02:40 PM
ford1977owner's Avatar
ford1977owner
1978 F250 4WD Supercab Pickup built at the Kansas City plant in June 1978 and powered by a 8 cyl 400 cid 2-bbl engine.
Old Feb 24, 2010 | 02:57 PM
thatsrealnice
n/a
thanks for the info!
Old Feb 24, 2010 | 02:58 PM
ford1977owner
anytime thats what were all here for!!
Old Feb 24, 2010 | 03:05 PM
Furyus1's Avatar
Furyus1
If the transmission is an automatic, have you checked the fluid level?
Old Feb 24, 2010 | 03:32 PM
starmilt's Avatar
starmilt
Make sure the Tcase is in gear.
Old Feb 24, 2010 | 04:51 PM
thatsrealnice
transmission
it's a 4 speed. my friend was looking while i put it in reverse and 2nd, and the driveshaft isn't turning when i let out on the clutch, i'm thinking it's a linkage or something, but someone else said it's the driveshaft, so not really sure.
Old Feb 24, 2010 | 06:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
WB155= 155" wheelbase
Color BR= (B) Dark Jade Metallic (R) Light Jade
Model X261= F250 4WD Supercab Pickup 7600 GVW
Body DFM= No DF listed Could it be DR? (DR) Jade All Vinyl (M) Not listed
Trans A= 4 speed manual, New Process 435
Axle 24J= (24) Dana 60 4.10 5300 lb capacity (J) w/ Power Steering
Old Feb 24, 2010 | 06:38 PM
thatsrealnice
vin
it is DRM, thanks a lot, that answers quite a few of my questions. wonder what the M could mean??
Old Feb 24, 2010 | 07:20 PM
bamaf150's Avatar
bamaf150
x2 on Starmilts question....
Old Feb 24, 2010 | 07:31 PM
thatsrealnice
shifting
wow. i feel really stupid. i was trying the 4 wheel drive out on it yesterday. which the right front hub won't lock out, (something else to be fixed). well i left the t-case in neutral thinking when not using 4WD that you leave it in neutral so that answers my problem. i don't know what i would have done otherwise so thanks to everyone who responded. so till my next dumb question have fun with your trucks!!
carllouis
Mar 23, 2017 04:11 AM
PW01
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 22, 2017 12:34 PM
nerksa
May 21, 2013 09:39 PM
50th ann
General Automotive Discussion
Mar 31, 2006 11:26 PM
trouble
Aug 17, 2002 11:41 PM
