86 6.9 250 starting problem
Old Feb 23, 2010 | 10:40 PM
rlwilson2's Avatar
rlwilson2
Just got a great running 86 diesel but it has an ignition problem... first the key will not turn the truck off and come out. second to start the truck you must turn the key to the start position and push the steering wheel up to make it start... any ideas... would this just be the tumbler and the switch or is it the ignition rod.... I am not opposed to a push button for the starter either...
Old Feb 23, 2010 | 11:50 PM
bghnkinf250's Avatar
bghnkinf250
do you have to push it up to turn it, or just for it to start?
Old Feb 24, 2010 | 12:36 AM
rlwilson2's Avatar
rlwilson2
Just to start... must turn key to start position and push wheel up... Would this just be the actuator??
Old Feb 24, 2010 | 10:08 AM
Franklin2's Avatar
Franklin2
If you have a tilt column, piece #14 usually breaks and causes this problem. The Ford dealer keeps them in stock, and now the parts stores may carry them too.
Old Feb 24, 2010 | 10:15 AM
rlwilson2's Avatar
rlwilson2
thanks... I may make a video of the repair if it is that common
TridentCrash
Nov 28, 2016 05:02 PM
AteThePrincess
1983 - 2012 Ranger & B-Series
Apr 24, 2016 03:16 PM
fastcat1977
22
Jan 30, 2016 09:04 PM
ride_gnu
Jun 13, 2013 04:25 PM
86BrownFord
Oct 24, 2010 06:37 AM
