I'M THINKING INJECTORS ORINGS
Old Feb 23, 2010 | 09:33 PM
fordpride's Avatar
fordpride
Today i started the truck after it's been sitting for 9 hours and nothing but smoke (gray 60*day) clears up after a min. but if i rev it reel hard it will stumble at 1800 rpm and blow smoke smells like raw fuel. runs about the same on hwy.but has a little miss at idle no CEL
Old Feb 24, 2010 | 04:43 AM
drivembig's Avatar
drivembig
I would think the same thing......sounds like O-rings to me.
Old Feb 24, 2010 | 06:09 AM
FARM69's Avatar
FARM69
Yep... definitely sounds like o-rings to me.
Old Feb 24, 2010 | 08:18 PM
fordpride's Avatar
fordpride
Thanks for the input guys. I ordered orings form RiffRaff on Mon. soi'll get them put in this weekend and i'll let you all know. If anyone else has any other thoughts on this please chime. Is there anything else i should lool for while the injectors are out.All suggestions will be appreciated. Thanks Mike.
Old Feb 24, 2010 | 09:24 PM
F350-6's Avatar
F350-6
Now would be a hood time to ohm your glow plugs and see if any need replacing before you tear into it. Also when you get in there, re-torque your lower injector hold down bolt to 120 in-lbs and the rocker arm pedestal bolts to 20 ft-lbs.
Old Feb 24, 2010 | 10:00 PM
FARM69's Avatar
FARM69
I'd replace them even if they are testing ok. Plus it's the easy way to get the oil out of the chamber.
Old Feb 25, 2010 | 07:26 AM
427 fordman's Avatar
427 fordman
I would too. They are only 80 bucks a set. Get motorcraft, they don't swell.
Old Feb 25, 2010 | 08:17 PM
fordpride's Avatar
fordpride
GP's replaced in dec.
Old Feb 25, 2010 | 08:30 PM
F350-6's Avatar
F350-6
You're gonna be pulling them anyway. I'd go ahead and ohm them to be on the safe side. New doesn't always = good.
Old Feb 25, 2010 | 09:40 PM
fordpride's Avatar
fordpride
injectors are out the tips are very dirtyand have some heat marks just above the copper seal i'm yhinking thats normal. injector cups look fine. GP's fine. but i need to know what i can clean the injectors tip's with i don't want to damage anything. had injectors out in a hour and a half
Old Feb 27, 2010 | 10:06 PM
fordpride's Avatar
fordpride
alright got it all back together and running took it for a 8 to 10 mile drive parked it went back out 30 min. later and it took longer to start than normal it use to start as soon as you hit the key now it about 12 to 15 sec. how long does it take to get all the air out of the fuel system.and could that be my longer cranking time
Old Feb 28, 2010 | 12:43 PM
Action4478's Avatar
Action4478
Yep...
They say to "drive it like you stole it" , may need 50 or so miles ...
Old Feb 28, 2010 | 08:26 PM
fordpride's Avatar
fordpride
Thanks to everyone shes back running at her best after 75 miles of running the pee out of it.
