Is this a common problem
Old Feb 28, 2010 | 12:26 PM
1996 f-250 7.3L's Avatar
1996 f-250 7.3L
Hey everyone. Is it a common issue on the 7.3L engines to have the 2 bolts on both sides of the engine that clamp the turbo-up pipes to the exhaust manifold to corrode and snap. I currently have a slight exhaust leak that is noticable under moderate to heavy acceleration. Bought new bolts and nuts, am going to drill out the old bolts and replace with a 3in bolt, lock washer and nut. I want to get it fixed ASAP because i know any type of exhaust leak before the turbo is taking away boost, which can kill fuel mileage and power. Just wondering if its a common problem and wondering if anybody else has run into this problem. Its an easy fix in my opinion. Thinking about taking some pics as i go through the process. Thanks
Old Feb 28, 2010 | 01:22 PM
donbrown's Avatar
donbrown
Our 1997 F250 with 235,000 miles does not have have exhaust leaks.
But with those temps and the quality of bolts used in the 1990's leads me to believe anyone trying to take out those bolts without a some luck and a good feel on how a bolt feels when it twists in half will have a snapped off bolt.
I think the best thing to do would be replacing the bolts that will resist the heat .... stainless?
Old Feb 28, 2010 | 01:39 PM
DRRXR's Avatar
DRRXR
Stainless is susceptible to Chloride Stress Cracking and has too much thermal growth.
A better alloy would be monel or hastelloy or even inconel.
Old Feb 28, 2010 | 06:08 PM
donbrown's Avatar
donbrown
How much would bolts made of this material cost ???/
Old Feb 28, 2010 | 07:16 PM
WALJON's Avatar
WALJON
X2 and sucks if you have to use a torch on it.
Old Feb 28, 2010 | 07:25 PM
F350-6's Avatar
F350-6
No idea, but I bet the kid at Home Depot won't be of any help.
Old Feb 28, 2010 | 08:30 PM
riverrat41's Avatar
riverrat41
I have welded inconel and hastaloy and I know they are expensive metals.
If you have a Fastenal in your area you may ask the about what bolts can take exhaust heat.They should know,they deal in all kinds of bolts.
Old Feb 28, 2010 | 08:38 PM
EMD_DRIVER's Avatar
EMD_DRIVER
What size are those bolts? I can talk to a Fastenal rep tomorrow... I need to change mine too...
Also, what size are the up-pipe to Y-collector bolts? May as well replace them too!
Old Feb 28, 2010 | 09:04 PM
F350-6's Avatar
F350-6
Don't know, but I tried the local hardware stores for those bolts on an 02 and the didn't quite fit. I ended up going back to Ford to buy those bolts. Surprisingly in stock and fairly reasonable for a Saturday.
bluemtn95ford
Jan 5, 2016 06:38 PM
eclipsemf
Apr 28, 2015 06:30 PM
Hvences
Apr 24, 2015 05:14 PM
John7894
Feb 22, 2006 02:25 PM
funzjb1
Jan 31, 2006 06:38 AM
