Transmission Questions
Old Feb 23, 2010 | 09:33 PM
Buckin_Bronco's Avatar
Buckin_Bronco
Hey guys I have a 1989 Ford bronco with a 351W. The truck currently has an AOD transmission off a 302. The AOD seems to have a lot of slipeage and has no grab at all, so I am just looking for a way to utilize my engines power better. I was wondering if a 5 speed manual would fit in place, or maybe an E40D. Thanks guys
Old Feb 23, 2010 | 10:00 PM
Blurry94's Avatar
Blurry94
I would suggest rebuilding your AOD instead. That transmission can be rebuilt for a reasonable price and stronger with the right parts.
To convert to a 5 speed or E4OD you need to relocate the crossmember and install a different length driveshaft. The 5 speed needs an extra pedal and slave cylinder and the E4OD needs a different harness, ECU and a pickup and an exciter ring (in the rear end for speed reference) because it is a computer controlled transmission.
Old Feb 23, 2010 | 10:06 PM
Buckin_Bronco
thanks man. any idea what a rebuild would cost on an AOD.
str8patina
Feb 15, 2016 04:43 PM
bankog1
Oct 14, 2015 02:07 PM
cek181
Jun 4, 2015 11:14 PM
ktlspop
Mar 23, 2005 08:08 AM
JasonBrod
1978 - 1996 Big Bronco
15
Feb 16, 2004 03:44 PM
