Vent Window Removal
Old 01-05-2011, 06:30 PM
59JEEPSTANG's Avatar
59JEEPSTANG
59JEEPSTANG is offline
Dreamtruck, I have taken apart Mustang vent windows and also later 76 & 84 vent windows and they are almost identicle as the ones above. Basically, you have to replace the pivot screws and put springs and nut on the bottom. Than 3 or 4 screws hold it to door and a couple bolt inside the door. You might want to look in one of the parts catalogs (such as NPD) as they usually have a parts diagram. 66 to at least 97 should be almost the same as far as mounting.
Paul
Old 03-13-2022, 01:43 PM
crmath's Avatar
crmath
crmath is offline
Pivot screws
Just pulled all my window stuff out, the frame fir my vent window still has 2 screws left holding it on. Problem is they are inside of the top of the frame. Any suggestions on how to get to them? Or is my only option cutting into the frame?
bigf350sd
1947 and Older Ford Trucks
18
10-22-2022 05:28 AM
mikey1968
01-05-2019 09:13 AM
eric8
04-11-2017 12:30 PM
joedellcarter
17
03-19-2017 11:20 PM
jvmcc
03-10-2016 07:39 PM
Quick Reply: Vent Window Removal
