Steering arm hits shock
Old Feb 23, 2010 | 06:10 PM
soooop's Avatar
soooop
Old Feb 25, 2010 | 09:34 AM
airharley's Avatar
airharley
It looks like your spindle stops are out of adjustment. One both spindles is a 1/2 inch bolt with a jamnut that limits the travel. See if you have them still installed on the backside of the spindle knuckle. All you have to do it raise the tires off the ground and manually move the steering to see if they are making contact before the linkages. To adjust them, loosen the jamnut and move the bolt as needed to make contact then tighten the jamnut again.
Old Feb 25, 2010 | 09:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Uh, this is the OP's SECOND thread he's typed on this subject. The first was typed: 2/17-2/19/2010.
The truck has an axle flip and (I think the OP said in the other thread) that it's been lifted.
Garbz2 already told the OP what procedure needs to be done to cure the problem.
Old Feb 25, 2010 | 12:06 PM
soooop's Avatar
soooop
Did this before any mods ?
I know what needs to be modified. My actual steering arm is hitting,not my draglink. This thread is to show the steering arm pic. With all the trucks on this forum I thought someone would recognize right away if it looked bent compared to others. Thanks for all the previous help. Looks like the arm is bent upward more than stock..?
Old Feb 25, 2010 | 12:40 PM
airharley's Avatar
airharley
If you look in my gallery you can see a stock unmodified arm from the front under the "disc brake" title. It may or may not help since you flip the axle.
Old Feb 25, 2010 | 07:00 PM
garbz2's Avatar
garbz2
It looks too high. I sent you back a PM. Lets tryy what i outlined then go from there.
Garbz
GETDOWN!!!
1997 - 2003 F150
46
Sep 23, 2009 11:43 PM
GETDOWN!!!
S. California Chapter
13
Aug 24, 2008 07:53 PM
GETDOWN!!!
Aug 15, 2008 02:53 PM
fabmandelux
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 25, 2008 12:34 PM
