Brake help
Old Feb 23, 2010 | 03:06 PM
Cap'nDewie's Avatar
Cap'nDewie
Brake help
To make a long story short. I replaced my front pads and rotors on my 1990 f150, had some complications and ended up having to replace all my front/rear break lines. the rubber ones and hard lines.
my problem is.. i'm trying to bleed the rear left tire and my bleeder valve is rusted beyond belief. Wrenches were stripping it so i had to result to vice grips. Messed it up even more. It's not going to budge. Is there a way i can bleed that wheel some other way or should i just replace the wheel cylinder. Id prefer not to replace it since i've already spent more money than i need to but i just wanted to check
Thanks,
Dylan
Old Feb 23, 2010 | 04:43 PM
Hitokori's Avatar
Hitokori
by breaking the brake line loose... and useing it like the bleeder valve...
Old Feb 23, 2010 | 05:50 PM
Cap'nDewie's Avatar
Cap'nDewie
I just went out and bought a new cylinder. but thanks anyways.
