Aerostar Ford Aerostar
PSOM/Code questions
Old Feb 22, 2010 | 07:56 PM
fishheds's Avatar
fishheds
PSOM/Code questions
Hey guys.First post here.Just wanted to ask if anyone here has had any problems with their PSOM/gauge cluster? While cruising along my '95 3.0 w/180k mi. will downshift to 3rd every now and then.Sometimes the speedo drops to 0 and the odometer goes blank.Sometimes the speedo pegs out to top speed but usually drops to 0.About half the time the speedo stays good with just the downshift.
If I give the dashboard a good rap-Fonzie style Ayyy!- the trans returns to O/D.I pulled the PSOM and checked the wiring the best I could but there's a sticker on the back of the cluster saying "don't disconnect before contacting Ford....etc".All the wiring looks good from the limited access I had with the PSOM still connected.
So #1-Can I disconnect the PSOM and stick in a compatible JY unit for "test" purposes?
I know I need to pull codes.I've got a reader but no code sheet.
Oddly enough,I've also got a '95 Bronco w 180k mi. w/Haynes manual.
So #2-Are the codes the same numerically for both vehicles?
Anything you guys can throw my way would be appreciated.
Old Feb 22, 2010 | 08:35 PM
99f350sd's Avatar
99f350sd
Back when I had a speedo issue i was reading about that. It seems that there could be a circut board issue a cracked trace maybe on the PSOM on the back of the cluster... I can't remember exactly..
Old Feb 23, 2010 | 05:30 AM
tom_foreman's Avatar
tom_foreman
I replaced my instrument cluster when I had this problem. Do a search on PSOM. You should find the discussion on it there.
Old Mar 6, 2010 | 02:01 PM
fishheds's Avatar
fishheds
Tom,did replacing the cluster solve your problem? Any tricks for the gear indicator? It looks like it could be a PITA.
Old Mar 7, 2010 | 07:04 AM
tom_foreman
That fixed mine. It worked fine until a tree fell on it. Changing it is not that hard. The indicator is actually a cable. Similar to a bicycle brake cable. It has an adjustment to fine tune the indicator.
Old Mar 7, 2010 | 09:25 AM
fishheds's Avatar
fishheds
Thanks,Tom.I pulled the cluster yesterday and checked connections. WD40'd the 2 of 3 I could get loose.I didn't want to press my luck with the 3rd until I have a replacement on hand.
I also pulled the cover around the steering column.When I removed the ignition lock,the little black wire terminal in the ignition cylinder came loose and wouldn't stay in place afterward.Duct tape to the rescue!
I'm gonna leave the dash trim out for a few days while trying to isolate the problem further.
Am I right in assuming the odometer mileage is stored in the computer,so when I do,if necessary,the cluster swap,the mileage will still be actual ?
Old Mar 7, 2010 | 09:41 AM
tom_foreman
Actually, I lost some 30-40K mile with my swap. I wrote it down for reference. But after it was totaled I didn't need it any more.
I remember that there is a setting having to do with wheel/tire size that you set in the PSOM. Thus the programmable part of PSOM. I think you can change it a few times in the life of the PSOM. I didn't notice any changes in MPH with mine so I didn't bother. Check the current value of the old before you swap and then check the new.
Try reading this https://www.ford-trucks.com/forums/6...-constant.html
Eddiec1564
Nov 2, 2025 01:10 PM
E55 Bulldog
Sep 23, 2019 11:15 AM
1995F150XLT4x4
Jun 7, 2016 04:46 PM
erupert66
Oct 4, 2013 04:19 PM
igotoneforya
1978 - 1996 Big Bronco
Apr 4, 2012 09:48 PM
