Sponsored by: Real Truck
turn signals
Old Feb 22, 2010 | 05:35 PM
tommy929's Avatar
tommy929
turn signals
my turn signals and 3rd brake light stopped working i cant find the relay or the flasher can anyone help
Old Feb 22, 2010 | 05:43 PM
1buzzbait's Avatar
1buzzbait
3rd brake light is bulbs co-inky-dinky---now any more info on the multi-function malfunction?? do they flash fast-not at all??
Old Feb 22, 2010 | 05:45 PM
twags6's Avatar
twags6
If everything went out at once, its most likely a fuse. Can you give us details on your truck?
Old Feb 22, 2010 | 05:55 PM
tommy929's Avatar
tommy929
checked all fuses and the lights dont work at all not even dim
Old Feb 22, 2010 | 05:58 PM
tommy929's Avatar
tommy929
1999 7.3 powerstroke
Old Feb 22, 2010 | 06:05 PM
twags6's Avatar
twags6
Did you pull them and check with an ohm meter? Sometimes its hard to see when one is blown.
As for the turn signal relays, I believe they're mounted up under the dash below the radio and heater controls.
Old Feb 22, 2010 | 06:19 PM
tommy929's Avatar
tommy929
i checked the third brake light the wire was burned i just fixed that as for the signals i gess i have to go get a shop manual and pull out the raido all the fuses was checked with a test light
Old Feb 22, 2010 | 06:54 PM
twags6's Avatar
twags6
Are all 4 completely dead? Do the hazard flashers work at all? Let me dig out my wiring diagrams and see whats all connected.
Old Feb 22, 2010 | 07:27 PM
twags6's Avatar
twags6
Do your brake lights work when you hit the pedal? If I'm reading the diagram right, and the relay crapped out, you should still have your hazard flashers. If those don't work, something might be wrong with the turn signal stick.
Old Feb 23, 2010 | 02:00 PM
tommy929's Avatar
tommy929
thank you for your help twag6.... i went out and bought a manual i will dive into it after the rain stops thanks again
Old Feb 23, 2010 | 05:10 PM
Fishin76's Avatar
Fishin76
If you need to get to the flasher, the easiest way is to remove the radio, look in and down to the left. One big blue relay (if original), and two small black ones side by side. There is a black cover with slots in the top of it covering the relays.
gogoat
15
Jun 19, 2025 08:11 AM
JefflovesF250s
Dec 13, 2016 08:16 PM
marty277
Feb 17, 2016 04:56 PM
makthenif
1997 - 2003 F150
Dec 4, 2015 06:46 PM
bks976
Jul 12, 2015 05:06 PM
