Cleaning Plenum...?
Old Feb 25, 2010 | 12:04 AM
traxx808's Avatar
traxx808
i remember a while back i saw someone use easy off oven cleaner on the plenum and took the grease off. i also noticed that it was very acid like because it was also sprayed on the block and it stripped the paint off the block.
Old Feb 25, 2010 | 05:11 AM
TexasGuy001's Avatar
TexasGuy001
I wouldn't use anything that strong, there is a coating on the inside of the intake and the throttle body that you don't want to remove.
Old Feb 25, 2010 | 09:36 PM
andyman91's Avatar
andyman91
Get some acetone i used that then get a old towel after you let it soak outside for 20 min and it cleans up good then just rinse it out.
Old Feb 25, 2010 | 10:53 PM
pete17c's Avatar
pete17c
maybe when there new .. but after +100K when the OE paint on the outside is peeling and you've got varnish on the inside .. not so much ..
anyone who has ever 'ported and polished' has removed any 'factory' coating there may have been .. and I've never hear of 'replacing' the coating ..
Old Feb 25, 2010 | 11:40 PM
Hitokori's Avatar
Hitokori
a coating on cast aluminum.... lol where do u all come up with this stuff?
and i dont see easy off eating the paint off... it hasnt ever done it every time u used it
maybe all the oil and gas that leaked out on it ate it off but not the oven cleaner
ive used it on lots of grills to and they still have the paint on them
Old Feb 26, 2010 | 06:56 AM
TexasGuy001
There is a coating inside the plenum and the throttle body from the factory. I don't know what it is or how important it is. I would guess that its there to prevent the aluminum from corroding which bare aluminum does.
I never said that that cleaning product would ruin it. I have never used that stuff for anything like this so I don't know how strong it is.
Old Feb 26, 2010 | 08:42 AM
pete17c's Avatar
pete17c
aluminum oxide, unlike iron oxide (rust), actually helps to protect the underlying metal .. so once it has this layer of 'oxide' it stops corroding ..
Aluminum is actually very prone to corrosion. However, aluminum corrosion is aluminum oxide, a very hard material that actually protects the aluminum from further corrosion. Aluminum oxide corrosion also looks a lot more like aluminum, so it isn't as easy to notice as rusted iron.
quote from here .. Does Aluminum Rust?
Old Feb 26, 2010 | 03:44 PM
rainbowATF's Avatar
rainbowATF
The coating is on the throttle plates from what I have read; so I used CRC throttle body cleaner there. But the upper intake I used on-sale generic brake cleaner and it did a great job. Acetone or naphta will also work but are rough stuff; flammable and evaporate quickly.
Old Feb 26, 2010 | 03:50 PM
Hitokori's Avatar
Hitokori
get a big bucket that the upper intake will fit in and fill it full of carb. cleaner and let it soak in it for a few days then take it out get a rag a little wire brush and some carb cleaner in a can and wipe it out scrub and all that good stuff that involves manual labor lol
idk how well that will work but it had worked wonders on carb.s
Old Feb 27, 2010 | 06:35 AM
TexasGuy001
That Berrymans' B12 stuff works good. I have a gallon can of it that even has a basket in it for soaking parts. It works really well. I know the can isn't big enough to soak the intake, but I bet it would clean up the intake pretty good. I agree with soaking it in a container big enough to hold it. Thats the best bet short of taking it somewhere to have it cleaned.
nstueve
62
Jul 20, 2022 08:21 AM
nstueve
80
Feb 5, 2016 12:33 AM
vardashan
Modular V10 (6.8l)
Jan 4, 2012 03:42 PM
dixie_boysles
1983 - 2012 Ranger & B-Series
Apr 3, 2010 02:26 PM
VoodooRacer
2004 - 2008 F150
Feb 6, 2010 07:54 AM
