rocker arm adjustement question
Old Feb 28, 2010 | 07:51 PM
mustang81's Avatar
mustang81
What if the springs are allready install ?
Old Feb 28, 2010 | 08:55 PM
zaaac's Avatar
zaaac
You will need to build an attachment that will thread into the sparkplug hole on one end and hook up to your air compressor on the other end. Then you can fill the cylinder with air pressure. This will hold up the valve while you remove the heavy spring and install the light spring.
Old Feb 28, 2010 | 11:36 PM
mustang81's Avatar
mustang81
I just found my pushrods are too long. Gonna buy a pushrod lenght checker.
Old Mar 1, 2010 | 08:55 AM
mark a.'s Avatar
mark a.
Don't forget to add the preload figure to the push rod length you come up with before youn order them.
Buyerz
Jun 19, 2016 10:27 AM
77_F150_4x4
Aug 8, 2014 04:44 PM
73 fourxfour
38
Feb 20, 2011 02:55 PM
tater_51
Dec 31, 2010 06:45 AM
mamafedmepaintchips
Dec 29, 2003 06:57 PM
