solenoid starting problems
Old Feb 21, 2010 | 10:03 PM
brhine_99's Avatar
brhine_99
i have a 84 f150 4x4 with a 4.9l in it. i have put two soleoid on it and will not keep a charge on the battery overnight. yesterday wen i charged the battery up to full and try to start it the solenoid clicked a couple of times and and the cable runnin from the solenoid to the starter got hot and started smoking and i lost all electric power. i changed the cables from the solenoid to the starter, the cable to the battery to the solenoid and the cable from neg size of battery to the engine block today. with no help to the problem. a couple of days before this when i was jumping it to get it started when i turrned the key the solenoid starting clicking so i shut the key off to let battery charge more and it still kept doing it like i was still turning the key so i pulled the jumper cables off and they were hot to touch and yes i had them hooked up right. could this be a short somewhere or do i need to replace solenoid again or wat. something is wrong where it burning solenoids up and not keeeping acharge overnight. the battery is good and the alternator is too . where do i go from here guys. need some help bad. i am lost lol .
Old Feb 21, 2010 | 10:28 PM
brhine_99's Avatar
brhine_99
also while going through some of the wiring i noticed the divert solenoid is broken in 2 pieces. wat does this do and could this be the problem and where do i get autozone says they dont carry it lol
Old Feb 21, 2010 | 10:45 PM
8525ford's Avatar
8525ford
make sure you got the solenoid hooked up right and has a good ground on the fender wall. the ignition switch wire i believe should be hooked up to the I terminal. ( the smaller terminal of the two closest to the battery when mounted on the fender.)
Old Feb 21, 2010 | 11:29 PM
xirxious's Avatar
xirxious
I seem to have the same problem. Mine had all new starter & solenoid on it and I've run it since replacing them.
Is the ignition wire the red or black? I thought I put them back on exactly as removed, but it has run previously.
Old Feb 22, 2010 | 02:06 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Sounds like you fried the fuseable link coming off the starter solenoid. Check the fuseable link, and replace if nessecery.
I would not buy a starter solenoid at autozone or anywhere else except from Ford. Aftermarket starter solenoids are prone to cause problems.
Old Feb 22, 2010 | 08:09 AM
brhine_99's Avatar
brhine_99
how many amp of fuseable link do i need and where can i get one at.
Old Feb 22, 2010 | 08:15 AM
sixesrock's Avatar
sixesrock
20 and at any auto parts store.
Old Feb 22, 2010 | 08:20 AM
brhine_99's Avatar
brhine_99
20 amp will be big enough fo the fusible link coming off the solenoid
Old Feb 23, 2010 | 01:48 PM
xirxious's Avatar
xirxious
Can you tell the fried links by looking at them? I just saw black blocks.
Old Feb 23, 2010 | 09:27 PM
brhine_99's Avatar
brhine_99
i couldnt tell by looking but i replaced them and now i have electric again. but when i turn the key solenoid clicks once then the ground cables get hot the one on the motor block will smoke. i can hear the starter clicking but wont turn over. i am going to take starter off tomorrow and check it out. hope that is it and no more probs. does anybody have any ideas lol
Old Feb 28, 2010 | 06:09 PM
JimBoB77's Avatar
JimBoB77
99 IF you are seeing smoke where the cable connects to the engine block, that is usually an indication that you have a bad connection there, like either it is loose or oil or rust or something stopping the connection. Your starter takes tremendous juice and MUST have a very good connection.
Old Mar 1, 2010 | 11:47 AM
brhine_99's Avatar
brhine_99
fixed my truck i replaced the starter and now it works fine. thanks to everyone.
bcrone821
17
Jun 10, 2015 01:55 AM
Wooticus
Jun 16, 2013 11:57 PM
InfidelReaper
Apr 2, 2013 02:54 AM
84F-250HD460
Apr 29, 2010 10:25 AM
ironelk
Electrical Systems/Wiring
Dec 3, 2005 10:29 PM
