Replace fuel lines with aluminium?
Old Feb 21, 2010 | 08:10 PM
kenpobuck's Avatar
kenpobuck
I have a leak in my lines somewhere as I can smell the fuel (raw fuel) when I am driving and even when it is sitting in the drive way. With all the snow and wet roads right now it is impossible to find where it is leaking. I found rolls of alminium fuel line at summit and wonder if it will work with diesel fuel? If so I think I will buy some and run all new lines on the beast, They are kinda a mismatched set up right now. I will run all new supply and return lines and try to clean lings up some.
Old Feb 21, 2010 | 08:16 PM
Red Cobra's Avatar
Red Cobra
im really not sure if the aluminum will be able to take the abuse... but if it works sweet
Old Feb 21, 2010 | 08:22 PM
87crewdually's Avatar
87crewdually
As long as the aluminum line is properly mounted securely and NOT rubbing on anything it would be fine. With the harmonics and vibrations of a diesel if anything was rubbing on the line it would wear a hole in it quick.
I'd suggest start by looking closely at the injector return lines. They are a more of a common spot to leak raw fuel where you would smell it in the cab.
Old Feb 21, 2010 | 08:27 PM
kenpobuck's Avatar
kenpobuck
I checked those today and they were all dry. I did have a problem with people moving them and had to replace the orings once. I don't let anyone touch stuff anymore lol. The body on this thing is in ruff shape right now so there are places air can get in I plan to do the body in the next couple years.
Old Feb 21, 2010 | 09:11 PM
starmilt's Avatar
starmilt
Kenobuck if you get a chance stop by a truck or trailer parts house and look at the nylon air lines. It is used on reefers for fuel line and might even be the same thing as our fuel line. It is extremely hard to wear out and would last forever. You buy it by the foot and it is around 50 cents.
Old Feb 21, 2010 | 09:46 PM
Marianna2003's Avatar
Marianna2003
I'm with Starmilt, Aluminum does not do vibration well. The nylon air lines are the smae material as the fuel lines. You could even try to heat the end in hot oil to push it onto the original fittings so you don't have a problem with fittings.
Old Feb 21, 2010 | 09:54 PM
WarOzz's Avatar
WarOzz
Yea nylon over aluminum in one of rattle happy trucks.
Old Feb 21, 2010 | 10:03 PM
stevilknevil's Avatar
stevilknevil
i have been thinking about trying the stuff they use on big trucks.i think its called stratoflex but i'm not sure,but it's probbaly pricey.
Old Feb 21, 2010 | 10:04 PM
starmilt's Avatar
starmilt
lol I have in an emergency when I didn't have a ferrule heated the end with a lighter till it curled, and made it hold air pressure.
Old Feb 21, 2010 | 10:05 PM
starmilt's Avatar
starmilt
You don't need stratoflex it is too heavy and bulky plus expensive.
Old Feb 21, 2010 | 10:09 PM
stevilknevil
lmao i thought i was the only redneck that has done that.
Old Feb 21, 2010 | 10:46 PM
starmilt's Avatar
starmilt
Nope I have done it a lot. Wheb I started running alaska the first trip I didn't even have a jacket, after that I started carrying all sizes ferrules, splices air lines, etc. but until then I've had to use a lighter quite a few times.
Old Feb 22, 2010 | 10:37 AM
Marianna2003
The hot oil in an old fryer where you can control the temperature will allow a more uniform heat.
Old Feb 22, 2010 | 10:41 AM
starmilt's Avatar
starmilt
You don't want to use a lighter to heat it to slip it over the fittings. Use either the hot oil method you described or a heatgun. I doubt seriously you would even need to clamp it.
Old Feb 22, 2010 | 08:16 PM
kenpobuck's Avatar
kenpobuck
Thanks I think we have a truck/trailer sales place up the road near walton. I will check them out soon. This weekend I have to help move my stepson and sunday go get the Bronco/plow trailered up and over to my buddies place for disassembly.
