two leaks under truck
I have two leaks underneath my truck 1 is a brake fluid leak and 2 is an oil leak. They are both fairly bad the oil leak is from the bottom near the oil pan not sure what it actually is.
The brake fluid leak comes from the front of the cab on the bottom, could it be the proportioning valve?
Anybody have similar experiences?
thanks
thanks
We'd need a MUCH better description of where the leaks are actually coming from for any of us to be any help. Oil / fuel leaking down the engine from the return lines is very common. Oil pan leaks are NOT common. Oil cooler leaks are common. Valve cover gasket leaks are uncommon, but happen.
Brakes could be proportioning valve, master cylinder, lines, etc. Clean off your engine bay and follow the leaks up to their sources.
If the brake fluid is running down the front of the cab its either the MC or the lines are leaking. Perportioning valve is on the frame rail.
fixitman1310
02-28-2010 09:10 AM
