now on back brakes
Old Feb 21, 2010 | 03:48 PM
drewdole's Avatar
drewdole
now on back brakes
after replacing back wheel clys. and back brakes and back brake hose and steel lines, you bleed back wheels then bleed rear abs module????? 93 f250 all stock 7.3 e4od 4x4. f350 uhaul 7.3 c6 1990
Old Feb 21, 2010 | 05:17 PM
Kleenax's Avatar
Kleenax
Just found this quote from a previous post here on FTE:
"Did you bleed the ABS module? It's under the cab on the driverside and has a bleed valve on it. Proper sequence for bleeding if I remember right is. Bleed rear first, then ABS, then front."
<!-- / message --><!-- sig -->
goodybrain2001
Jan 14, 2014 09:59 PM
colokerrie
Dec 26, 2012 11:08 PM
efka
2004 - 2008 F150
Aug 27, 2011 09:19 AM
dozerdug
Jul 23, 2011 07:59 AM
94f2507.3td
Aug 5, 2004 06:52 PM
