Bleeding brakes
Old Aug 25, 2011 | 10:10 PM
efka's Avatar
efka
Bleeding brakes
I changed the front flex brake lines and when I was bleeding the back I noticed that I forgot to close the hose screws under the wheel wells. Lots of air got into system. What is the way to bleed them now. Cam air get into abs pump or somewhere else that requires dealer to connect the computer? Or it's just regular procedure starting from furthest point?
Thanks
2007 f150 fx4
Old Aug 27, 2011 | 09:19 AM
TwinSkrewd's Avatar
TwinSkrewd
You should be able to start from the farthest point. It is always difficult to say where air has travled to. I would bleed the entire system. While your at it pick up a set of the quick bleeders and some 1/8th or 3/16 rubber hose from your local autoparts store. This will save you some time and the trouble of a helper plus allow you to drain the blowout into a container. When all is done test the brakes and the anti-locks to ensure proper performance.
High_HP
Jun 9, 2021 11:02 AM
Headviking
Jul 31, 2011 12:27 PM
Herman R
Mar 22, 2007 07:28 PM
aeomholt
Dec 23, 2004 05:23 PM
cahil
Nov 8, 2004 05:32 PM
