transmission question
Old Feb 21, 2010 | 10:30 AM
coyotecrusher's Avatar
coyotecrusher
Unhappy transmission question
Hi im new to the sight ive been searching for a answer about my 1986 f150 4x4 the tanny seems to be quick shirting like it goes from 1st to overdrive in at 15mph i lose power and if i stomp the gas it picks up i put $1000.00 in the tranny and im pissed the man said he rebuilt it i do believe him the place that did the want does alot of trannys in a year rebuilt a coulpe of my buddys transmissions just really frustated ford 150 4x4 302 hi output 1986 any info would be appreciated thanks.
Old Feb 21, 2010 | 10:37 AM
Jigger2020's Avatar
Jigger2020
does yor truck have a throttle rod or cable that goes up to the carb? is it an AOD or an AOD-E tranny,Gigger What did the repair shop say when you brought it back?
Old Feb 21, 2010 | 10:42 AM
coyotecrusher
aod and i believe it a cable
Old Feb 21, 2010 | 10:43 AM
coyotecrusher
they said they did all they could do and to shift from 1st through 3rd manully
Old Feb 21, 2010 | 10:45 AM
83mike's Avatar
83mike
sounds like the TV cable needs to be adjusted. Mine was doing that too for a while till i got it right. It's very picky.
Old Feb 21, 2010 | 10:51 AM
Jigger2020's Avatar
Jigger2020
ok, if the cable is not adjusted tight enough the tranny will upshift to fast, with the engine turned off,push the gas pedal to the floor & the cable should be tight,this will give you passing gear when you stomp the gas on the highway & tell the tranny when to upshift under normal accelleration,Gigger
Old Feb 21, 2010 | 10:53 AM
coyotecrusher
thank you ill keep u informed
